Anorak's Corner
(Moderator:
AshimotoK0
UV bonding
Topic: UV bonding (Read 4783 times)
paulbaker1954
I'll just be 5 minutes dear!!
UV bonding
April 25, 2020, 08:20:09 AM »
Does anyone have any experience with UV resins for repairing plastic parts. I usually resort to reaching for the Superglue but seen some outrageous claims for this UV stuff. Seems to me that only really good for transparent materials as otherwise the UV will only cure the bond edges
Any other recommendations for high strength plastic repairs?
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
AshimotoK0
Moderator
Mad Scientist.... more power Igor ! Ù©(̾à¹Ì®Ì®ÌƒÌ¾à¹ÌƒÌ¾)Û¶
Re: UV bonding
April 25, 2020, 10:02:01 AM »
Funnily enough that UV stuff comes up as an advert on YouTube recently with all sorts of claims but I have no experience of it. Interested to see if anyone else on here has tried it out too.
I have been using this epoxy in the link for years .. takes ages to cure but by mixing different fillers (i.e aluminium ultra fine power, ground ceramic and talc, coloured epoxy pigment etc you can do all sort of repairs. If you put enough filler it it forms a putty. You can vary the hardness by using more or less hardener (it's in the data sheet). Don't confuse this stuff with rapid epoxy in little tubes .. totally different.
https://uk.rs-online.com/web/p/potting-compounds/1991468/
Quite expensive but lasts for years
Datasheet :
https://docs.rs-online.com/3543/0900766b81580057.pdf
There is also the superglue trick and baking soda .. The baking soda makes the adhesive cure instantly plus it fills gaps (wet item with superglue and sprinkle the baking soda on) But I still stick with the RS epoxy stuff myself.
Last Edit: April 25, 2020, 10:08:02 AM by AshimotoK0
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.†Grace Slick, Woodstock '69 .. In the year of the Sandcast.
bobv7
SOHC Expert
Re: UV bonding
April 25, 2020, 10:35:32 AM »
Got this via some crowd funding thing. Waited ages for it to turn up and so far haven't managed to permanently fix anything with it. Could be I'm doing something wrong or using it on the wrong materials but I thought it was supposed to fix anything.
gtmdriver
SOHC Expert
Re: UV bonding
April 25, 2020, 04:34:58 PM »
A long while back I tried out some UV activated pre-impregnated fibreglass patches. They sell them for things like emergency canoe repairs.
It worked fine on the sunny day I chose.
mickwinf
Re: UV bonding
May 02, 2020, 09:24:16 PM »
I used some on a pair of binoculars which i dropped on the first time i used them! first attempt did not work but on the second try i shone the light for longer and then built up the repair with a bit more of the glue, this did work well and is still ok. However i have tried a couple of other things without success and i think it is about how the uv light can penetrate.
paulbaker1954
Re: UV bonding
May 03, 2020, 08:59:08 AM »
From my research seems like only works well on transparent materials where the UV can reach to cure.
PHILIP2908
SOHC Associate
Re: UV bonding
May 03, 2020, 10:52:58 AM »
Hi Again,
My dentist used UV bonding on my fillings; just plastered it on and shone a light into my mouth for 20 secs. Strong stuff, still holding together 12 months later.
1974 Honda XL250 K0 - Silver - owned for 32 years. Not running at the moment
1972 Honda CB750 K2 - Now candy apple red - Ex USA, a DK special - needs a lot more work than I thought - very quickly becoming a DS special...
Anorak's Corner
(Moderator:
AshimotoK0
UV bonding
