SOHC.co.uk Forums > CB350/400
CB400F Ressurection - Cam Chain Adjuster Housing Damaged
SeanFD:
I hear what you say.
Does anyone have any experience of these from Legend Motorcycles?
https://www.ebay.co.uk/itm/Honda-CB400f-Brand-New-Pair-Of-Fork-Tubes-1975-1977-Stanchions-400-4-400-four/113669408153?hash=item1a77398599:g:ZG8AAOSw18BceVFO
Another question. The mudguards – apart from the holes in the rear – and the chain guard clean up to an acceptable, for now, level. I’ve got most of the surface rust off using vinegar and a scotch pad.
If I could stop the flash rust turning them brown within 30 mins, I’d be content to use them. A coat of WD40 works to a point, but would obviously wash off. Anyone know of anything a bit more permanent?
Incidentally, I contacted IKON Suspension in USA – I got a great service from them when replacing my 750 suspension – and Nils there told me that spares for the 76 series Konis, predecessor to the 1076, are not available. So it seems I need new shocks; the bump stop disintegrated completely when I was dismantling it. :(
SeanFD:
Has no-one any ideas on how to stop flash rusting on what’s left of the chrome on my mud and chain guards?
Nurse Julie:
--- Quote from: SeanFD on May 05, 2020, 01:52:34 PM ---Has no-one any ideas on how to stop flash rusting on what’s left of the chrome on my mud and chain guards?
--- End quote ---
Wipe the chrome over with an oily rag.
SPR:
ACF50 ?
Golfcarmad:
Not sure if my solution helps-but it was cheap and has worked:
A right mess of camshaft tensioner thread on outer casing.
So I tapped a new thread M8 dropped a ball bearing in crewed in bolt with lock nut-So now it’s more a manual adjustment but worked fine.
Hope this idea helps-you have nothing to lose trying it before you spend hundreds/new cases.
Navigation
[0] Message Index
[*] Previous page
Go to full version
