Author Topic: Handlebar wiring direction help  (Read 4153 times)
Offline 4wDaz
« on: April 29, 2020, 02:11:27 PM »
Hi guys I’m currently putting a bike together that I didn’t strip down and need a bit of help regarding the handlebar wiring route and how the two bundles of wires run when they exits the hole in the middle of the handlebars, I’ve tried to look at pictures online but some run the pair of wires to the left hand side of the ignition switch and some split them and run one to the left and one to the right. Id like to run them as the factory did so if anyone can offer any help it would be appreciated, thanks Daz  :)
Genuine And Aftermarket Motorcycle Parts Supplier
Offline Deano400
Re: Handlebar wiring direction help
« Reply #1 on: April 29, 2020, 02:14:31 PM »
This should help.
Online Nurse Julie
« Reply #2 on: April 29, 2020, 02:32:35 PM »
After they come out of the handlebar hole, both then go over the top frame tube, go around by the left hand tank rubber, there should be a clip to hold them.
Offline 4wDaz
« Reply #3 on: April 29, 2020, 02:38:06 PM »
So one to the left and one to the right of the ignition switch then. Thanks very much  :)
Offline Deano400
« Reply #4 on: April 29, 2020, 02:44:28 PM »
Yes. This may be a bit clearer.
Offline 4wDaz
« Reply #5 on: April 29, 2020, 02:51:11 PM »
Perfect thanks again  :)
