CB350/400
Indicators will not flash
3
Topic: Indicators will not flash (Read 12670 times)
Golfcarmad
SOHC Associate
May 09, 2020, 12:33:02 PM »
Hello everyone.
Well the 400 is finally finished.
Starts on the button-sounds awesome.
Only problem now is indicators don’t flash-they come on-front and rear and console.
Relay clicks once-but no flashing.
Every other lightetc works perfect.
Relay swapped for working item-still no wink wink.
Open to suggestions please?
Paul
More bikes than sense!!
Honda 400/4 (almost fully rebuilt)
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Honda CBR500F (Import)
Francis Barnett Plover
Puch Maxi 2 speed (makes me smile)
Cb100n cafe racer
50cc scooter (now does 52 mph)
Johnwebley
Re: Indicators will not flash
May 09, 2020, 12:53:01 PM »
Are you using standard bulbs?
mike the bike
CB400F, Royal Enfield Interceptor.
May 09, 2020, 12:54:40 PM »
Supposed to be 12V, 21W blubs. Are you certain that the replacement flasher relay works ok.
Golfcarmad
SOHC Associate
May 09, 2020, 02:45:55 PM »
Thanks for advice.
New indicators are 10w bulbeds (not LED).
Pulled all my lovely wiring apart and connected 21w indicators to right hand side-
No difference-still no flashing.
I don’t think I need to connect all 4.
Confident new relay works fine as fellow forum member sent it to me after checking it works.
So where next??
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
billywingnut
SOHC Associate
May 09, 2020, 03:36:35 PM »
It's usually bad earths if your wiring is standard
bobv7
SOHC Expert
May 09, 2020, 05:03:39 PM »
"It's usually bad earths if your wiring is standard"
Second that.
Nurse Julie
May 09, 2020, 05:06:53 PM »
I third that 😊😊😊
Golfcarmad
SOHC Associate
May 09, 2020, 05:12:44 PM »
Ran Earth direct to frame then direct to battery-no difference.
On basis not an earth issue,any other thoughts-please?
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
philward
May 09, 2020, 05:18:17 PM »
Think I had this when I built CR Rep - seem to remember (was a few years ago) it was the wires the wrong way round on relay? (aftermarket relay was used)
Johnwebley
May 09, 2020, 05:19:07 PM »
Remove the relay.
Is it a standard unit?
See if you can try it on another vehicle.
Should work on cars etc.
SumpMagnet
Reply #10 on:
May 09, 2020, 05:23:08 PM »
I usualy go for a step by step appraoch with wiring...
Disconnect the indicators.,.... then connect just hte earth side. Apply 12V to theother indicator wire...see if it lights. Then reconnect...and go to the next step in the wiring to see where it tkaes power from ...like the relay. Disconnect...and apply voltage...see if the bulb lights. And so on. Once you know the basic wires connect corectly, and hte switch operates...then worry about the relay.
BUT....if none of them are working, and the earths are good, Most likely it's the relay or the switch.
CB750F2 - in pieces
Golfcarmad
SOHC Associate
Reply #11 on:
May 09, 2020, 06:33:19 PM »
Just to confirm-indicators and console light all work-just no flashing.
Relay is genuine item and working before being posted to me a few days ago.
However will try all suggestions offered.
Many thanks
Paul
Triumph TR25W
Yamaha Virago 1100
Suzuki GSX750ES
Yamaha Virago 535
Cb100n cafe racer
mike the bike
Reply #12 on:
May 09, 2020, 06:45:22 PM »
It's unlikely to be an earth fault if the bulbs light up. The relay relies on 44.2W of bulbs, (which takes 3.8amps) to discharge the internal capacitor so you get the correct flash rate. That's 2 x 21W plus the little one. If you go sticking 10W bulbs in or LEDs, it isn't going to flash.
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
Reply #13 on:
May 09, 2020, 06:45:54 PM »
Maybe it was damaged in the post?
They are mechanical after all.
Reply #14 on:
May 09, 2020, 08:48:59 PM »
Frequently need engine running for flashers to work
3
CB350/400
