Author Topic: CB400F trip reset grommet installation order  (Read 6354 times)
Offline Winterfield
« on: May 11, 2020, 09:17:16 AM »
Hi all,
I've been keeping myself busy with my restoration, and have just stripped and repainted my clocks.
The trip reset meter grommet on the speedo was wrecked, and it looks like cb750faces is out of stock until July(?).
I'd like to put the speedo back together now, and install the grommet later when they're available.
Will this work, or does the grommet need to be installed before reassembling the speedo?
Cheers,
Ken
Online kent400
Re: CB400F trip reset grommet installation order
« Reply #1 on: May 11, 2020, 05:19:24 PM »
The grommet is glued to the inside of the body and plus the fact you can't you can't get the grommet over the knob. You can't usually remove the knob from the shaft without damage.
Offline Winterfield
« Reply #2 on: May 12, 2020, 09:26:51 AM »
Thanks, yeah, I did have to destroy the knob taking it off, unfortunately.
So now when I'm putting it back together, I just have the bare shaft. I don't want to crimp down the ring only to find that I can't install the grommet after sealing the whole thing up.
Offline waffey
« Reply #3 on: May 14, 2020, 02:01:53 PM »
I started my clocks. I had to destroy the black knob taking it off. It was suggested that toothpaste top, filled and blacked could be a good substitute.
Bikes:
Triumph Street Twin
Suzuki Address 110 Scooter
Suzuki TL1000s
BMW R1200GS LC
« Reply #4 on: May 14, 2020, 03:18:35 PM »
Some tubes of glue have tops about the right size and already black. ☺
Offline 4wDaz
« Reply #5 on: May 14, 2020, 07:04:20 PM »
I ended up making one for mine after destroying the plastic 1
Genuine And Aftermarket Motorcycle Parts Supplier
« Reply #6 on: May 14, 2020, 07:38:59 PM »
I feel a production run coming …
« Reply #7 on: May 14, 2020, 07:46:59 PM »
:D ;D
Offline 4wDaz
« Reply #8 on: May 14, 2020, 08:14:09 PM »
;D Making them is the easy bit, its getting the time to do it that’s hard. I’ve not even got a spare minute to do my own stuff  :-[
« Last Edit: May 14, 2020, 08:16:43 PM by 4wDaz »
« Reply #9 on: May 14, 2020, 08:21:38 PM »
Trust me. We understand.
I don’t pretend to be skilled enough to make stuff.
Finding the time to ride the bloody thing is bad enough!
« Reply #10 on: May 15, 2020, 12:36:18 PM »
I am a complete  novice on the lathe but teaching myself to use one during lockdown  (see my other post today) .... How do you achieve the knurling on that knob?
Offline 4wDaz
« Reply #11 on: May 15, 2020, 12:54:39 PM »
Its done with a knurling tool, have a look on Youtube for knurling on lathe, its dead easy to do
