Author Topic: Front Wheel assembly  (Read 3217 times)
Offline waffey
« on: May 15, 2020, 04:01:49 PM »
Hi,
respoked my front wheel. I am putting it together but question the locking tabs that i took off. Is this an original OEM to lock the flange nuts to the disk or has someone added that as the nuts i took off where plain nuts
Bikes:
Triumph Street Twin
Suzuki Address 110 Scooter
Suzuki TL1000s
BMW R1200GS LC
Re: Front Wheel assembly
« Reply #1 on: May 15, 2020, 04:14:21 PM »
Original
Offline waffey
« Reply #2 on: May 15, 2020, 05:12:38 PM »
Thanks, attached disc side, shiney or black? it doesn't show in my manual
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
« Reply #3 on: May 15, 2020, 06:47:45 PM »
I think its the black side as the chrome ring on speedo drive should stop bolt heads turning, look in manual under wheel dissasembly
Offline TrickyMicky
« Reply #4 on: May 15, 2020, 07:31:09 PM »
Ironically, it's only today that I have removed the disc from my 400, also to have the new rim and spokes fitted. To the best of my knowledge it's the 1st time that the disc has been removed, and I've owned it since 1989, (it's a 1976 model). There were no tab washers under the fixing nuts as they are flange nuts. The tab washers you have pictured would be OK for ordinary plain nuts, but would not do their job properly on flange nuts. If my memory serves me correctly, the last time I saw these was on a CB750 rear sprocket. Just use the flange nuts, making sure that the mating surfaces are nice and clean and use a torque wrench for the required tightness. If ever we get back on the road, looks like it could be a good year for shiny wheels!!! Regards, Mick.
Offline ttr400
    • CB400F special machined parts
« Reply #5 on: May 16, 2020, 05:49:49 AM »
The lock tabs are from the CB350 Four. used with plain nuts.
The CB400F did not use the tabs, they only had the Flanged nuts.
Kevin
If you are addicted to the little CB400F then you might want to check out my website.
www.ttr400.com
Offline waffey
« Reply #6 on: May 16, 2020, 02:53:09 PM »
Thanks all.
i'll ditch them off the four and use the flange nuts i purchased
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
