SOHC.co.uk Forums > Recommended Sources for Parts and Services
welding
<< < (2/2)
mtrhead:
do you know if can he do ally welding as I've got a broken lug on my 550F engine case?
thanks
Oggie400F:
Hi Mtrhead
Yes I’m pretty sure he can do ally welding.
I remember him mentioning he was repairing an engine casing for someone when I picked up my BIL’s petrol tank.
Trigger:
I do alloy welding to engines but, i am far from Buckinghamshire. Depends what part of Bucks you are in ? T&L engineering maybe closer in Bedford  ;)
mtrhead:
Thanks for the replies!
I'm near High Wycombe in Bucks, after working at a glacial pace (years!)  I've got the head and barrels off the CB550F2 and though I can't see anything too worrying (other than the stuck piston/rings needing replacement) I'm probably going to split the cases, check the bottom end and get the motor mounting lug (that I stupidly broke trying to get the engine out the frame on my own!) welded.
Alan
Seamus:
T and L are very good folk. Used them a few times for various bits. Old school engineers. Definately worth a call (01234 352418)
Navigation
[0] Message Index
[*] Previous page
Go to full version
