Author Topic: New member UK 500  (Read 11173 times)
Offline simonc
Re: New member UK 500
« Reply #15 on: May 25, 2020, 11:51:17 AM »
its only muck lad, nice enough bike with promise tank does look t 500, if you would like to sell exhaust i would be interested. ;)
one job leads to another
cb72 1964
cb550f1 1976
cb550f1 1976
cb550 1977 with cb 500k engine
Offline SteveW
« Reply #16 on: May 25, 2020, 11:55:41 AM »
Check your main battery ground, it looks like you have the same problem as I had with my 74 550.
In your pic, see below. It looks like the green earth wire has overheated and melted. This happened in multiple places in my loom. Its caused by a poor battery ground connection, so a lot of current is using the only other path it can, the small green earth wire.
The second pic below is my loom, this is what to look out for:
« Last Edit: May 25, 2020, 11:59:15 AM by SteveW »
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Offline mickandsej
« Reply #17 on: May 25, 2020, 11:58:29 AM »
The motad is off and available, I’ve docs referring to it being fitted by MTC (Reading) in 1992. It needs cleaning which I intend to get onto but the chrome is good. Sounded fine and very little loose stuff inside it. I just preferred symmetry hence I bought the 4-2 for it.
Offline mickandsej
« Reply #18 on: May 25, 2020, 01:24:16 PM »
Thank you, I’ll look into that ASAP.
Offline Green1
« Reply #19 on: May 25, 2020, 08:01:11 PM »
That looks like a 750 tank to me.
Wasn't the tap on the 500T on the left and the tank had a slight indent for your knees and looks a bit more bulbous
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline mickandsej
« Reply #20 on: May 25, 2020, 10:03:52 PM »
750 is the closest match so far, next time I’m fiddling with it I’ll pull the tank and photo the underside. The bottom seam is concealed - it doesn’t have a flange showing, it’s flush all the way along the sides if that’s a clue.
Offline Menno
  • www.tanklackieren.de
« Reply #21 on: May 25, 2020, 11:25:26 PM »
It is indeed a Honda cb 750 k2 tank.
Offline mickandsej
« Reply #22 on: May 26, 2020, 12:11:13 AM »
Thank you! I’ll start looking for the right tank now....
Offline Menno
« Reply #23 on: May 26, 2020, 08:57:18 AM »
I have a nice set in gold... you can trade in the green set.
I am looking for a k2 tank anyway...
« Reply #24 on: May 26, 2020, 09:11:23 AM »
Gold is the best
Especially Menno’s gold.
Offline mickandsej
New member UK 500
« Reply #25 on: May 26, 2020, 09:50:53 AM »
Who could not be interested in that colour!!
I think the question is this:
I traded an old classic car for this bike, so I could free up space and still have room for a project. When the bike arrived I instantly changed my mind from full restoration to fix, ride and enjoy as is, warts and all, because of the seemingly genuine patina. I wrote off the idea of sourcing a 4-4 system as a new one was unaffordable and decided to go for good used parts even if not OEM, eg I’ve already put used chrome rear shocks on. The wiring is a mess and needs doing piecemeal. I’ve been over the engine with petrol and a toothbrush and it’s greatly improved (whatever happened to the old Gunk formula!? The new one is crap!).
Does anyone see anything else that suggests this bike is a bitsa/mongrel or do you think it’s better served being restored as a genuine UK bike?
And thank you all for the constructive input received so far!
Mick
« Last Edit: May 26, 2020, 10:18:49 AM by mickandsej »
« Reply #26 on: May 26, 2020, 10:08:06 AM »
Here is a UK CB500/4 K1 (This is owner by him indoors, Trigger)
Sent from my I3312 using Tapatalk
« Reply #27 on: May 26, 2020, 10:47:13 AM »
Summerfield Close is part of my morning dog walk!
Small world...
Offline mickandsej
« Reply #28 on: May 26, 2020, 10:54:24 AM »
No way!
Here’s a bit more local history for you then....
« Reply #29 on: May 26, 2020, 11:00:11 AM »
That frame number ties up with other 73 reg K1 UK models, unless you go to Honda UK and pay about £30 its dificult to give an exact date as Honda were building K1 models for the UK  and at the same time K2 models for elswhere plus just starting the 550 K0 for the US.
Personally i would put the proper tank on it, UK colours would be Gold, Brown or Black, painting tank and panels as and when and correct all the "wrong" parts as you go and have both time and cash.
Firstly give it a full service and mot, even though you dont have to have one, gives a good idea of what is worn then start on the rest. For example rear indicator brackets are wrong, no rear grab handle, fork gaiters look odd but resolution not best so cant be sure, front mudguard wrong(thats the dearest bit!)
« Last Edit: May 26, 2020, 11:16:19 AM by Bryanj »
