Author Topic: Headlamp bulb  (Read 2251 times)
Headlamp bulb
« on: May 25, 2020, 01:55:51 PM »
There's several listings on Fleabay for headlamp bulbs.  £26.95 for 10.  I'm tempted to buy a pack, I'll have enough to last until I'm 300 years old.
Re: Headlamp bulb
« Reply #1 on: May 25, 2020, 02:07:18 PM »
Which bulbs are those?
Re: Headlamp bulb
« Reply #2 on: May 25, 2020, 06:43:29 PM »
As above, which make?
I've used bulbs professionally with Phillips and Osram being the best makes technically.  Rarely have a failed one in H4, H7 and H1 types of halogen bulbs so not often have to buy them.  Car suppliers usually do them in pairs so you have a spare for bike use that'll probably get toward 20 years use out of them.
Re: Headlamp bulb
« Reply #3 on: May 25, 2020, 07:10:41 PM »
I'm just looking for VT parts.  Here's the listing...
Fits Honda VT 250 F (Europe) 1983 Bulb - Headlight - 1 (Per 10) 34901-950-003
Re: Headlamp bulb
« Reply #4 on: May 25, 2020, 07:59:26 PM »
Had a look and can't tell much about them, assuming picture is accurate too.
Guess you'll have to suck-it-and-see if nobody has any direct experiences on here. Presume somebody is just boxing them up from third party supplier so pot luck what you get from a technical and durability point.
As you say though,  a box should last you a while.
Re: Headlamp bulb
« Reply #5 on: May 26, 2020, 07:51:27 AM »
Difficult to tell but looks like a standard H4 fitting
