Author Topic: CJ250T  (Read 19614 times)
Offline AndyD
CJ250T
« on: June 19, 2020, 06:17:24 PM »
Hi,
Started stripping the CJ to assess condition and plan restoration of the handsome beast.
I just wondered if anyone had any experience of these bikes in terms of known issues, weaknesses or areas to check on the engine so I can make sure to go through these as I progress.
Cheers,
Andy
Re: CJ250T
« Reply #1 on: June 19, 2020, 06:24:12 PM »
Centrifugal oil filter on end of crank inside clutch cover needs cleaning and rarely gets done, cam chain tensioner system same as 400 four, lots of oil changes and insulating tape inside points cover to stop them shorting intermittently.
Dont thrash it from cold it will shatter rings and carb diaphragms, along with standard caliper/master crud problems
Anything else?
Re: CJ250T
« Reply #2 on: June 19, 2020, 07:48:51 PM »
Cam notorious for seizing in the head and trashing itself, the rockers, head and cover..... the cam bearings are just a machined into the alloy head  and cam covers ... oil starvation is usually  down to P.O. not changing the oil regularly and, as Bryan says, there is no easy access to the centrifugal oil filter on that model.... it requires removing the clutch cover. My first course action would be to take off the cylinder head cover and look for signs of oil starvation and take it from there.  Bottom ends are usually fine and the 5-speed gearbox is said to be an improvement on the 6-speed G5.
Forks and swinging arm are longer than the 400/4 and G5 which I think was done to improve the handling.
Original 2into1 exhaust systems are rocking horse poo and hence very expensive (often worth as much as a complete running bike). Wheels and disc brake are common to the 400/4 and G5 models. Rectifier terminals corrode and drop off.
« Last Edit: June 19, 2020, 07:51:28 PM by AshimotoK0 »
Offline AndyD
Re: CJ250T
« Reply #3 on: June 20, 2020, 07:44:44 PM »
Thanks guys,
Engine fully stripped this morning - had to wait for a castle nut tool to remove the centrifugal oil filter thingy.
So far looks promising but have now given everything an initial degrease / clean so I can have a close look at all the bits tomorrow.
You're both right about the oil filter - the centrifugal bit was pretty well solid gunk and the oil filter pretty messy, however there didn't seem to be any major damage evident from initial look (although may be different once I have a closer look at cleaned bits).
I've got two pretty well complete 250's, a spare 250 engine and a complete 360 so hoping to have enough good bits to get two full bikes up and running.
The 360 has a really good condition exhaust on it although the silencer is for the 250 - I'll probably use that on the 250 as a full restoration and the 360 as a decent runner with some universal silencer or other.
From the stripdown it seems the cam chain tensioner is different to the 400 with a simpler horseshoe mechanism - again all seemed in decent condition so far.
Cheers,
Andy
Offline bobv7
Re: CJ250T
« Reply #4 on: June 21, 2020, 09:50:20 AM »
After all the flurry of triumph and success of the multi pot bikes Honda along with several other major Japanese bike manufacturers seemed to suffer from a collapse of imagination. From what I remember this bike appeared to be a genuine Honda stop gap "parts bin", very cheap, special with no great expectations of it having long and heathy service life. I personally know of 2 identical very low mileage machines expiring with major valve problems. At about the same time folks discovered that some of the new? CB500T had valve stems that would bend under the pressure of a hard stare. Honda had got a bit lost at that time but unlike the British bike industry recognised this and managed to find a way back.
Re: CJ250T
« Reply #5 on: June 21, 2020, 10:07:33 AM »
PDI and sold a lot of the G5 and CJ bikes, the only time they suffered engine problems was if thrashed from cold by the owner, 175's were the same, OR oil change and centrifugal filter neglected, owners would specify NOT to clean the filter due to time cost and gasket, in which case they were told to get it done elsewhere. There were also the Numpties who removed the cam cover to try and force more cam chain tension.
Offline bobv7
Re: CJ250T
« Reply #6 on: June 21, 2020, 10:48:42 AM »
Not to disagree but these bikes were the Japanese the equivalent of what used to be called "grey porridge" when applied to small capacity British bikes. Still high on the success of the late 60's, early 70's, all four Japanese makers were treading water in the knowledge they had no real competition in the small to medium market. Mid 70's and being kind, you could call some of their offerings novel, eg.the CX500 and the unwelcome return of the oil leak; but their main focus was on the sales of larger capacity and more lucrative machines with everything else taking a back seat.
Offline cooleronthecoast
Re: CJ250T
« Reply #7 on: June 21, 2020, 11:27:22 AM »
Best of luck with your resto Andy but if I was looking to do up another SOHC Honda it wouldn't be a CJ, they weren't really that desirable when they were new.  But then again mebbe thats the appeal, I'm guessing but I assume they are quite rare now?  I've certainly never seen one since the early 80's
« Last Edit: June 21, 2020, 11:37:25 AM by cooleronthecoast »
Now where did I put that 10mm socket?
Re: CJ250T
« Reply #8 on: June 21, 2020, 11:36:16 AM »
 Horses for courses  ....I say if you like the bike go for it.. it wasn't as pretty as the G5 but handling and gearbox much better.. .. I think they are becoming more collectable particularly for cafe racers.
Re: CJ250T
« Reply #9 on: June 21, 2020, 01:38:51 PM »
They were the last Honda 250 "learner" bike as i remember before the 125 restriction came in, could be wrong there the memory is getting old
Re: CJ250T
« Reply #10 on: June 21, 2020, 01:52:28 PM »
No, the last ones were the Superdream 250's Bryan, as when the law changed they became worthless, as no one wanted one after passing the test, they were only a couple of mph faster than the last unrestricted CB125 twins, and the unrestricted 125's started climbing in price, a bit like unrestricted mopeds Fizzy's and AP50's and SS50's did.
Offline Rozabikes Tim
Re: CJ250T
« Reply #11 on: June 21, 2020, 01:54:53 PM »
Ditto CB250RS single
Offline AndyD
Re: CJ250T
« Reply #12 on: June 21, 2020, 02:01:52 PM »
Cheers all,
Agree they're not the least bit desirable but maybe that's a bit of the charm!
Only really got them as the 250's were just too cheap to ignore some years ago and the 360 came with the 400/4 which is still sitting on the naughty step while the ongoing carb flooding issue has seen us fall out badly.
I think they were just a misjudged design choice at the time and hard to imagine anyone at Honda bragging about being involved in bringing the CJ into the world.
My real love is the big 4 cylinder 4 strokes but I must say it is quite nice working on something smaller, simpler (and lighter) for a change.
Cheers,
Andy
Re: CJ250T
« Reply #13 on: June 21, 2020, 02:51:19 PM »
Knew my brain was addled with guiness!! Forgot totally about the wet dreams
Offline motty
Re: CJ250T
« Reply #14 on: June 21, 2020, 04:20:14 PM »
Obviously I'm a bit odd, but I have always had a soft spot for the CJ250/360. The plain yellow tank and black side panel have an appeal.
Good luck with the restoration, I will look forward to any updates
Sent from my Moto E (4) Plus using Tapatalk
