Author Topic: Indicator stem threads  (Read 3506 times)
Offline mickandsej
« on: June 25, 2020, 08:26:02 PM »
Can anyone tell me what thread OEM stems have? I’ve been through all my boxes and can’t find any that fit!
Re: Indicator stem threads
« Reply #1 on: June 25, 2020, 08:48:29 PM »
What bike do you mean? Do you mean the clamp bolts on the stems?
« Reply #2 on: June 25, 2020, 09:14:55 PM »
Do you mean indicator stems for a 500/4🤔🤔
Offline mickandsej
« Reply #3 on: June 25, 2020, 09:33:37 PM »
Yeah, it’s the rear stems, I’ve got the nuts at the front but don’t know what the thread is. All OEM as far as I can tell.
Offline mickandsej
« Reply #4 on: June 25, 2020, 09:34:03 PM »
500/4 BTW
« Reply #5 on: June 25, 2020, 09:42:57 PM »
These are 500/4 OEM, so yours are like this are they
Sent from my I3312 using Tapatalk
Offline mickandsej
« Reply #6 on: June 25, 2020, 09:51:55 PM »
I don’t thing mines the same as yours - the stems I have match those on the front. These holes are blank, not threaded, go through to hold the mudguard.
« Last Edit: June 25, 2020, 09:53:49 PM by mickandsej »
« Reply #7 on: June 25, 2020, 09:56:14 PM »
You have lots of bits missing, like the plates, rubbers, washers etc, etc, etc. The stems you have are not OEM for rear of this model.
Offline mickandsej
« Reply #8 on: June 25, 2020, 10:02:21 PM »
I thought so but they have the same thread as the front ones, if I can source the nuts I can put them on without some bodged brackets. Bike is off the road on the lift, this is the last job to do on the rear end, then I can spin it round and do the forks, caliper seals, brake hoses/line, throttle cables, headlamp wiring, and just get out and ride it!
It’ll have to remain a bitsa for now, but I love riding it as is
« Reply #9 on: June 26, 2020, 05:34:45 AM »
The nuts are supposed to be part of the chromed mudguard and originally would have been 6 or 8 mm
« Reply #10 on: June 26, 2020, 10:56:04 AM »
Get a thread pitch gauge,  dirt cheap and will last you forever.
Offline mickandsej
« Reply #11 on: June 26, 2020, 09:40:30 PM »
Sorted, got these of eBay and they fit perfectly.
