Cb550k3 Rectifier
Topic: Cb550k3 Rectifier (Read 7756 times)
mike the bike
CB400F, Royal Enfield Interceptor.
Re: Cb550k3 Rectifier
Reply #15 on:
July 05, 2020, 08:57:23 AM »
Mine was the standard Honda item. The difference between the OEM one and what you've got is, maybe, the heatsink. Yours might run a bit too hot and break down. You can always add a heatsink to it if you think it's inadequate. With a smidge of heatsink paste.
Johnny4428
Reply #16 on:
July 05, 2020, 11:42:44 AM »
Thanks for that I did wonder about the heat side of it. I will keep an eye on it after a couple of longer runs, I will probably replace at some point with the correct item in keeping with the bike spec. (he says with his electronic ignition)🤫
nairb
SOHC Member
Reply #17 on:
July 05, 2020, 05:04:51 PM »
I made up several sets of replacement rectifiers years ago expecting them to fail..... Some with heatsinks and others without. Not one has failed. Not had a battery go flat either.
Another useful thing from fleabay was a small digital readout. I put some long wires on and clipped it to the handlbars to check the charging voltage. Nice to see for a few days. All worked as it should with the new setup. They seem to be reliable
cb550k3, cl450k5, re5m, xs650xs2, mt500, kettle, gt550 x2, gt380 Kz750 twin, cb360K0 and an old working bicycle
Johnny4428
Reply #18 on:
July 05, 2020, 06:47:23 PM »
That’s interesting to know. Had my first run out with bike this afternoon, checked rectifier on return and only slightly warm. Funny thing I was wishing I had a volt gauge on the bike to keep an eye on charging.
Orcade-Ian
Reply #19 on:
July 05, 2020, 07:41:21 PM »
Hi Johnny,
I had the same problem of wanting to know battery voltage on our MX-5 - the ECU does the regulating and they seem to charge at or near 15volts, which I am a bit uneasy with. Anyway, I bought a couple of very cheap voltage displays and fastened one to a cigar lighter plug to do some checking. You could easily adapt one of these with long wires to somewhere visible - even inside the side panel would give readings you could check occasionally.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Johnny4428
Reply #20 on:
July 05, 2020, 08:45:09 PM »
Nice one Ian. 15v seems high! I actually have a small round double usb socket with voltage display I had purchased to fit to the Pan I possibly could do a temporary fit to the 550. Turned out to be nice day later on, didn’t expect to be out on the bike today but managed a run around. Cheers!
Johnny4428
Reply #21 on:
July 06, 2020, 09:13:11 PM »
Temporary set up to check charging circuit.
Johnny4428
Reply #22 on:
July 07, 2020, 09:46:18 PM »
That is very neat. I watched some of this guys engineering videos, he is a bit of a genius. I don’t think I’m even worthy of owning a hacksaw never mind using one after watching Allen in action.
Johnny4428
Reply #23 on:
July 07, 2020, 10:50:04 PM »
It was Amazon. Flip up the cover and it’s a double usb socket. Bought to fit on my Pan. I have an unmolested low mileage model so was reluctant to cut into the plastic. Might make a bracket or something. Really just purchased more for the usb sockets than the volt meter, but makes sense to have both.
nairb
SOHC Member
Reply #24 on:
July 08, 2020, 12:00:39 AM »
Those usb ports are great for charging the mobile phone. I keep a portable one in my motorcycle jacket so I can connect it to any of my bikes. Even charge on the go. Make you wonder how we manged years ago.
Johnny4428
Reply #25 on:
July 08, 2020, 10:26:47 AM »
Very handy! Do you just have clips on it to clip to battery terminals?
nairb
SOHC Member
Reply #26 on:
July 08, 2020, 06:39:36 PM »
Just use the croc clips to the battery. I'm sure a more sophisticated way could be done but it works for all the bikes I have. Its the purple thing in the pic. I think it came in other colours too. It does work!. I have charged the phone up several time over the years. Just get an data cable that suits your phone.
It saves having to charge the phone before you set off.....
Johnny4428
Reply #27 on:
July 12, 2020, 07:06:21 AM »
Thanks guys for input and help! Bike is charging as it should so moving into phase 2 and going to spend another £4.
Flag connectors heat sinc and cable ties of the appropriate colour Steve. 😂😂
Johnny4428
Reply #28 on:
July 12, 2020, 08:45:19 PM »
Nice run out tonight 38 miles. Interesting monitoring voltage at battery during run. Had broad range from 12.4 to 15volts, I guess that’s the regulator acting on demand, mostly it sat at 14.4volts. Not sure if that would be normal.
. [ Guests cannot view attachments ]
deltarider
My kingdom for a turkey!
Reply #29 on:
July 13, 2020, 11:14:59 AM »
14,4 is perfect.
Cb550k3 Rectifier
