Author Topic: Defective battery or charging problem or other?  (Read 17398 times)
Offline cliff7
Re: Defective battery or charging problem or other?
« Reply #45 on: July 11, 2020, 10:24:44 AM »
Poking my nose in, after similar problems found this helpful:-
http://manuals.sohc4.net/general/motorcycle_electrics/HondaMES3.pdf
Forget first page.
Offline billdn
« Reply #46 on: July 11, 2020, 04:03:43 PM »
Cliff any help appreciated, will read link but can't say I'll understand it ;)
Bryan - I've repeated earlier test you asked and values shown as follows(previous in brackets)
Battery volts engine running 12.47v (12.2v) with negative probe on battery and pos on white wire to block 3.3v, no previous ; pos on black in headlight 12.12v ( 0.73v) ; pos on black ignition 12.16v ( 0.73v); pos on ignition red 0.05v ( 0.49v) so cleaning up ignition switch may have done something?
Bill
« Reply #47 on: July 11, 2020, 06:14:07 PM »
You should still have a higher voltagd on the white wire, more or less full battery voltage after startup.
There are two sets of contacts inside the reg box, or rather one moving one that connects up or down depending on battery voltage. It could be that one of those pairs have high resistance and need cleaning, same as engine contact points realy they can oxidise when not in use
« Reply #48 on: July 13, 2020, 10:38:04 AM »
As I said;  short black and white together.  This bypasses the questionable voltage reg and supplies the full 12V across the exciter coil.  All being well, it should now charge, so replace the voltage reg.
If it doesn't charge, then the fault is elsewhere.
Offline billdn
« Reply #49 on: July 13, 2020, 02:55:37 PM »
Bryan - removed regulator, gave points within clean with fine wet/ dry ( dry obviously) and a good spray with electrical cleaner and put back on , no change or possibly lower value on white than before, tried Mike's suggestion and charging ok , so possbly u/s regulator.
A combined rectifier/ regulator is cheaper than new regulator from DS any thoughts?
Or try and source second hand unit from Steve and 400/4 bits.
Cheers Bill
P.S. horn now works - loose wire oops!
« Reply #50 on: July 13, 2020, 02:59:49 PM »
What the reg does is, when it detects the battery voltage is low, gives a 12V output to the white wire.
Yours isn't doing that.  The test you carried out proved that the reg is faulty.  I would get a combined reg/rec from DSS.
Offline billdn
« Reply #51 on: July 13, 2020, 03:12:43 PM »
Mike thanks for that👍 wemoto do similar and are local to me so could pick one up to save waiting, are you aware of any problems with this unit, I guess it'll need some support bracket as won't fit directly in place?
« Reply #52 on: July 13, 2020, 03:22:15 PM »
Or post me the reg and i will fix it, the standard regs are very reliable and the only difference between 400 and all the other sohc is the way the contacts point
« Last Edit: July 13, 2020, 03:23:48 PM by Bryanj »
Offline billdn
« Reply #53 on: July 13, 2020, 03:52:10 PM »
Nice one Bryan can you PM me your address? 👍
« Reply #54 on: July 13, 2020, 08:38:11 PM »
Make sure it's a 3 phase one.  You mentioned Lexmoto,  they only do small bikes front they?  The Lexmoto 125 that I'm fettling is only single phase.
Offline billdn
« Reply #55 on: July 14, 2020, 08:34:34 AM »
Mike- no Wemoto not Lexmoto, they're a parts supplier and do good quality parts at reasonable prices. I've used them before , worth a look if you've not seen them on t'net - do mail order too!
« Reply #56 on: July 14, 2020, 10:33:45 AM »
Doh, brain fart 🧠💨.  I've used Wemoto many times.  Go for it.
Offline billdn
« Reply #57 on: July 14, 2020, 04:06:33 PM »
Okay! So going for Elextrex RR24 rectifier / regulator - have removed old regulator (off to BryanJ to have a look and thanks for that, may come in handy for other 400 I have) , looks quite straight forward but I'm bit concerned by this part referred to in parts manual as rectifier assembly (ringed in red) should i remove this and 2 red/green wires feeding it also.
Also any tips on mounting it, noted other threads for 550/4 etc but none for 400/4 - guess doesn't need earthing but needs to be kept cool to dissipate heat I guess?
« Reply #58 on: July 14, 2020, 05:29:02 PM »
The new reg/rec. replaces both the regulator and the rectifier.  Bin the old regulator but hang onto the the old rectifier,  it can be useful for someone if it works ok.  If you mount it in the same position as the old rectifier it'll get enough airflow to keep it within temperature parameters.
Offline billdn
« Reply #59 on: July 16, 2020, 02:54:53 PM »
Success!👍 new rectifier/regulator fitted and all works fine! Thank you one and all for your patience , knowledge and advice! Even found a secure mounting spot!
