Fuel stabiliser
Topic: Fuel stabiliser (Read 6420 times)
JezzaPeach
SOHC Expert
CB500/4 K1 1972 gold
Fuel stabiliser
July 01, 2020, 04:34:52 PM »
Hi all
Just interested if anyone has used anything like Sta-Bil.
I’m a bit sceptical but after a year or two period of storage, and gummed slides etc, I cleaned my jets etc and put in Sta-Bil, all fine, but then didn’t bother for a while, and had a blockage in #2, which cleared with lots of choke/throttle open, and now I’ve started using it again. It seems to help but interested if anyone has a similar tale which may help others with erratic running.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Re: Fuel stabiliser
July 01, 2020, 05:29:49 PM »
Just put seafoam in both oil and fuel of my mates GL 1500 trike and within 5 minutes the hydraulic lifters went quieter and the tickover improved. The yanks swear by the stuff, will report more in a few months
mickandsej
SOHC Associate
Re: Fuel stabiliser
July 02, 2020, 10:18:03 AM »
A mate has just put it in his VT bobber and Beezer, I’m waiting to hear the results..
K2-K6
Re: Fuel stabiliser
July 02, 2020, 10:27:41 AM »
On the original subject post, it looks like some form of stabilisation additives may improve keeping. Just difficult to decipher alot of the "puff" claims that come attached to most products
Whether there's anything identifiable in them that can't be found in normal products, I'm unsure. With machines I'm looking after running two stroke premix appears to be quite stable even after storage, appearing to prevent corrosion and blocking within even the smallest jets.
The Seafoam, I can see the origins in USA for improving gummed hydraulic valve lifters (unfamiliar with Goldwing, does it use hydraulic adjustment? ) but their confidence as a fix all solution I feel is misplaced. Looking at the MSDS data for it, diesel, naptha and isopropyl alcohol, should remove "gumming " from high mileage and carbon sludged systems, so can see that as need in some situations but would question it's effect within a sohc Honda engine.
http://hildstrom.com/projects/seafoam/
independent overview here.
K2-K6
Re: Fuel stabiliser
July 02, 2020, 10:48:47 AM »
The fuel stabilizer looks like just diesel and naptha (lighter fluid, otherwise known as
) with red dye added to make it look "special" and get more money for it in a branded bottle.
Bit like buying "pancake mix" instead of using egg, flour, milk
JezzaPeach
SOHC Expert
Re: Fuel stabiliser
July 02, 2020, 11:34:19 AM »
I think I’ve seen posts using soaking in diesel to help remove the laquer on carb rebuilds. Certainly not a cure all, I’ll keep testing it as given a low annual mileage and I don’t have the other ingredients separately.
K2-K6
Re: Fuel stabiliser
July 02, 2020, 11:43:06 AM »
It does appear to have some merit, just not the magical qualities that the bumff projects.
This quoted from another site but closed discussion;-
"Generally speaking, the oxidation that occurs happens catalytically. Once a trace amount of a type of decomposition known as radical formation occurs, it's a downhill cascade. Stabilizers (which btw are not detergents) act as dead ends for these catalytic cycles. You can look up what exactly a radical is, but generally speaking all you need to know is that it's highly reactive and leads to all sorts of pathways that don't normally happen and leads to sever decomposition.
The mechanism, no matter what the stabilizer is roughly the same. The radicals are still there, just occupied in the form of the stabilizer, which doesn't propagate a cascade to further degrade whatever it's in.
All sorts of things can trigger the initial degradation; from oxygen, to light, to thermal decay.
Stabilizers are used in everything industrially. An example of such stabilizers that's extremely common even in the food we eat is something called BHT, which is also used as a common stabilizer in many solvents."
From which you can see the aim of using something.
JezzaPeach
SOHC Expert
Re: Fuel stabiliser
July 02, 2020, 02:38:07 PM »
Interesting many thanks. I will test my old pals who did a Chemistry degree on this!!
I think one problem on mine was the pet cock was ‘letting by’ so as fuel evaporated, more was replacing it making the build up worse.
gtmdriver
SOHC Expert
Re: Fuel stabiliser
July 03, 2020, 07:29:22 AM »
The FHVBC tested a lot of fuel stabilisers when E5 was first introduced and found a handful that actually worked. I use Ethomix from Frost Restoration and drain the system before I lay it up for the winter.
Laverda Dave
Health is wealth
Re: Fuel stabiliser
July 03, 2020, 02:17:57 PM »
Intresting thread. I have never used any form of stabeliser. I run the engine with the fuel switch off until the float bowls run dry and the engine dies. If I am intending to lay the bike up (3 months +) I'd drain the fuel tank. One tip I was given that has never failed is to fill up using premium grade fuel, either Shell or BP appear to work best I've found. Using premium petrol seems to allow the bike to stand for months on end with no ill effects (running the float bowls dry though). My Morini started third kick this week having been laid up since March.
One bike none of the above applies to is my 1999 VFR, I don't know if its because of it being fuel injection but it can be laid up for six months and it starts on the button using normal pump fuel.
JezzaPeach
SOHC Expert
Re: Fuel stabiliser
Reply #10 on:
July 03, 2020, 07:51:00 PM »
Yes I’m trying to switch off the pet cock to at least drain the hoses and some of the float bowl to keep the float valve clear.
Yes I’ve heard injection makes a bit difference. Car SOS fitted one to a Hillman Imp for that reason, as well as performance. A kit for a sohc 4 would be nice, but expensive.
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
Re: Fuel stabiliser
Reply #11 on:
July 03, 2020, 08:06:40 PM »
Don’t forget that your VFR would have been running at about 40psi (my 2001 Fi-1 did).
That doesn’t leave a lot of room for any build up.
Fuel stabiliser
