Author Topic: Failing condensers  (Read 5336 times)
Offline hubster123
Failing condensers
« on: July 08, 2020, 10:03:48 AM »
Hi.... I’ve just put this on the sohc world forum, not knowing there is a UK one......
Can anyone give a reason for a condenser continuously failing.
I’ve replaced the condenser for 1 and 4 cylinders 4 times now with less than 100 miles on all of them put together.
Last night I was out on the bike and another one failed. Fortunately I was carrying another which failed after a couple of hundred yards. All four have been from different manufacturers
Offline hubster123
Re: Failing condensers
« Reply #1 on: July 08, 2020, 10:05:16 AM »
The scenario is bike running fine, then starts running really rough so that to get home I have to really keep the revs up. I feel the headers and 1 and 4 are cold.
I swapped the condensers round and 1 and 4 headers are hot while 2 and 3 are cold.
So I buy new condensers and the problem is solved for a short while. Then again, it starts running really rough and 1 and 4 headers are cold. So I replace the condenser for 1 and 4 and lo and behold the problem is solved again.. Then the same thing happens again, so I replace the condenser for 1 and 4 again... runs for a few miles no problem then it happens again... and so on and so forth
« Reply #2 on: July 08, 2020, 10:32:00 AM »
Are you sure it's the condensers?
It COULD be the coils.
As they warm up. They start to fail.
Are they original?
Offline hubster123
« Reply #3 on: July 08, 2020, 10:41:06 AM »
I don’t know if the coils are original as in fitted when new but they are stock ones.
Would a bad coil cause a condenser to fail though.. Like I say, if I fit a new condenser it all works fine but then that condenser (specifically for 1 and 4 cylinders) stops working
« Reply #4 on: July 08, 2020, 10:50:47 AM »
It could also be using R plugs and resistance plug caps.
Have you checked the caps to make sure they are not "burnt ".
They should measure 5k ohms.
Unlikely all the capacitors are faulty.
Offline hubster123
« Reply #5 on: July 08, 2020, 12:38:27 PM »
Right....thanks.... Unfortunately I don’t really know what that means.. I can say though that I took the coils to my motorcycle mechanic in January and he checked them with a meter (all the readings were correct) and as per his recommendation, I changed the plug caps (NGK)..
I know where you’re coming from re it being unlikely that all the condensers are faulty, but when I put a new one on, the bike runs fine and if I swap the ‘faulty’ one (from 1 and 4) with the one that runs cylinders 2 and 3, then 2 and 3 won’t fire.
« Reply #6 on: July 08, 2020, 12:56:51 PM »
The resistance in the plug cap burns out over time.
Massively increasing the resistance caused ignition problems.
If you have access to a multi meter you can check they are still 5.000 ohms
« Reply #7 on: July 08, 2020, 01:25:42 PM »
Did the problem start just after changing the plug caps?
They could be faulty or fakes, or not making a good connection with HT leads.
As John said, resisted caps and resisted plugs used together don't run properly.
Offline hubster123
« Reply #8 on: July 08, 2020, 01:39:59 PM »
No.... it was there beforehand.. What is strange is that if cylinders 1 and 4 stop working and I swap the condensers round, 1 and 4 work and 2 and 3 don’t.
Could faulty plug caps cause this issue?
« Reply #9 on: July 08, 2020, 03:12:50 PM »
This one is a strange one, need to try and figure out what is the difference between the 2 ignition systems. I know its a pain but swopping the coil wiring and seing if the same condenser fails might be worth it.
Offline hubster123
Failing condensers
« Reply #10 on: July 08, 2020, 03:17:51 PM »
Okay..... which wires would I swap. A friend suggested something along these lines and that I would also need to swap the ht leads round as well as the blue and yellow ones to the coils... but I couldn’t do this due to the lengths of the ht leads.
« Last Edit: July 08, 2020, 03:19:25 PM by hubster123 »
« Reply #11 on: July 08, 2020, 04:34:13 PM »
You would need to swap ht as well, would they reach if you swopped the coils from one side to the other?
Offline hubster123
Failing condensers
« Reply #12 on: July 08, 2020, 04:50:51 PM »
Chaps... I’ve bitten the bullet and ordered the Dynatec coils and electronic ignition.... Thank you all very much for your comments and help...
