Author Topic: K1 full restoration begins  (Read 31795 times)
Offline WestYorkshireBiker
Re: K1 full restoration begins
« Reply #30 on: July 14, 2020, 10:01:15 PM »
Note: Drawn by Ashimoto , Checked S.B. Devotion  ;D
(Attachment Link)
Awesome!! Thanks Ash
Sent from my ONEPLUS A6013 using Tapatalk
OW MUCH????????????
« Reply #32 on: July 25, 2020, 09:31:25 AM »
Bit more 'progress' on the old girl. Was thinking about the engine and how to paint it. Once stripped down do you vapour blast first I guess. But what was the factory paint on the engine. I'm keeping her as factory as I can tbh. Thanks.
OW MUCH????????????
« Reply #33 on: July 25, 2020, 11:29:02 AM »
Never vapour blast a engine, you will be asking for trouble using vapour as it contains glass bead.
I build engines for a living and have found the best way is a acid dip that has chemicals suited to cast alloy  ;)
« Reply #34 on: July 25, 2020, 11:40:55 AM »
A nice looking project.. do you get over to squires cafe? Plenty of nice old jap bikes to look at on a thursday eve through the summer
« Reply #35 on: July 25, 2020, 11:42:18 AM »
Thanks Trig. I read about this and honestly wasn't sure what's best. I've got the origional K1 which came with the bike. So the engine ,(K6) in the frame is being replaced. One of the K1 linings is cracked (not stripped it down yet so don't know what else is wrong). Is it Ok if I pm you at some point in the future as I'll be needing your services etc. Thanks.
OW MUCH????????????
« Reply #36 on: July 25, 2020, 11:43:49 AM »
Never been but planning to. I've an 'modern' SV650 so thought of popping over.
OW MUCH????????????
« Reply #37 on: July 25, 2020, 11:51:10 AM »
Any day is a good day to visit squires...but thurs night is classic bike night and there is loads to see....japs, british... italian... def worth a visit, you’ll be hooked once you’ve been  :D
« Reply #38 on: July 25, 2020, 11:55:28 AM »
Thanks. I'll keep that in mind.
OW MUCH????????????
« Reply #39 on: July 25, 2020, 12:24:50 PM »
The K6 to K1 barrels and liners are not interchangeable and the head is different. You will see the differences once you have the engines stripped so, keep all engine parts separate, one on one side of the workshop and the other on the other side ;)
« Reply #40 on: July 25, 2020, 12:29:56 PM »
Didn't think so. Already got two spaces in the garage for K1 and K6. Ta pal.
OW MUCH????????????
« Reply #41 on: August 10, 2020, 01:32:40 PM »
So I found these marks when cleaning the K1 head. The head came separately from the bike (as did the engine) but is this machinable or scrap! Thanks.
OW MUCH????????????
« Reply #42 on: August 10, 2020, 01:48:18 PM »
A head skim and those valve seats need a regrind, also check the valve guides . Are you sure it is a K1 head ?
« Reply #43 on: August 10, 2020, 01:52:21 PM »
It just came with the original engine in bits as the bike has a K6 in it. The bike is a 1971 but not sure tbh. What else will show if it's a K1 or not?
OW MUCH????????????
« Reply #44 on: August 10, 2020, 02:32:23 PM »
Head and barrels are different on a K1 to K6  ;)
Show me a picture of the head side on and the top face and a front, top and side picture of the barrels and i will tell you if they are K1.
