Author Topic: K1 full restoration begins  (Read 31790 times)
Offline WestYorkshireBiker
Re: K1 full restoration begins
« Reply #45 on: August 10, 2020, 02:46:19 PM »
Thanks. Head has a K3 stamp in it but not sure if that helps!
A head skim and those valve seats need a regrind, also check the valve guides . Are you sure it is a K1 head ?
It just came with the original engine in bits as the bike has a K6 in it. The bike is a 1971 but not sure tbh. What else will show if it's a K1 or not?
Sent from my ONEPLUS A6013 using Tapatalk
Head and barrels are different on a K1 to K6  ;)
Show me a picture of the head side on and the top face and a front, top and side picture of the barrels and i will tell you if they are K1.
OW MUCH????????????
« Reply #46 on: August 10, 2020, 03:31:23 PM »
Barrels are not K1, Head looks K1 but, i need a picture straight down of the top of the head
« Reply #47 on: August 10, 2020, 03:37:02 PM »
Like this?
OW MUCH????????????
« Reply #48 on: August 10, 2020, 05:31:48 PM »
Could you post a clearer picture of this jet for Trigger please. I've tried blowing it up on my phone, (the pic that is 😁😁😁) but it's quite blurry
« Reply #49 on: August 10, 2020, 05:41:44 PM »
Could you post a clearer picture of this jet for Trigger please. I've tried blowing it up on my phone, (the pic that is ) but it's quite blurry
(Attachment Link)
Here you go. I removed the o ring and placed it next to the jet.
OW MUCH????????????
« Reply #50 on: August 10, 2020, 06:11:46 PM »
Yep, That is a K1 head with a pepper pot jet. DO NOT Damage the jet as these cost ££££  ;)
« Reply #51 on: August 10, 2020, 06:21:37 PM »
Thanks. Appreciate the help. On with the bottom end tomorrow. Micrometer at the ready!
OW MUCH????????????
« Reply #52 on: August 10, 2020, 08:13:29 PM »
Looks like that needs a new set of gearbox bearings, remove all the oil way bungs and give it a good clean  ;)
« Reply #53 on: August 10, 2020, 08:21:58 PM »
Yeah it's getting all bearings / o-rings etc etc replaced. Been stood for God knows how long. No rust I can see as it had some oil in but not much. Total restoration and rebuild.
OW MUCH????????????
« Reply #54 on: August 12, 2020, 09:05:35 PM »
So I was looking at the con rods today and found that none of the usual 1,2 or 3 markings are stamped on. Any idea what the stamps in the pic actually mean (there's no markings on the other side of the rods). I've got the chart to get the correct bearings using the rod and crank journal from the Hondaman book and some plastigauge but not sure why all the rods have these different markings!
Yours sincerely Worried from West Yorkshire.
(Also not sure if it's a '2 or 7' in the pic)
OW MUCH????????????
« Reply #55 on: August 12, 2020, 10:57:07 PM »
Early con rods are weighted differently to the later type and have different markings.
Make sure you know what journal they cam from and what way round that they came off. Do not get these mixed up  ;)
« Reply #56 on: August 12, 2020, 11:08:00 PM »
Thanks again Trig. I've marked all the rods as I took them off so all ok there. Just got thrown by the lack of markings! Ta.
OW MUCH????????????
« Reply #57 on: August 12, 2020, 11:10:50 PM »
Does the other side of the rod have Japanese markings on them ?
« Reply #58 on: August 12, 2020, 11:16:01 PM »
Not that I could see. They were all blank.
OW MUCH????????????
« Reply #59 on: August 12, 2020, 11:25:32 PM »
Any markings that look like these
