SOHC.co.uk Forums > CB500/550
front brake
Nurse Julie:
--- Quote from: cooleronthecoast on July 13, 2020, 04:31:52 PM ---
--- Quote from: florence on July 13, 2020, 03:48:10 PM ---oh, and if it squeals, that's good! Mine seems to be working best when it's noisy. When it goes quiet, it's time to adjust.
--- End quote ---
Mine's just started squealing. Perhaps its getting better. ;)
--- End quote ---
Mine 550 does a quiet squeal and she stops perfectly. My 400 does a very, very loud squeal, only at slow speed, but she stops perfectly as well 😁😁😁😁
Johnwebley:
When you got a new master cylinder. Did you get a twin disc larger bore version?
oldtuggie:
got new master from David Silver 14mm piston I believe
Johnwebley:
When I did my twin disc mod I used a Goldwing master cylinder.
On the cylinder I have its marked 15.8.
You need to push more fluid because you now have double the pistons
JezzaPeach:
Just speculating but if not all the air came out, may be worth putting on the side stand so the master is at an angle and pumping to see if some more bubbles come out in the master?
Also I found the EBC semi sintered is good. Has taken 2-300 miles to get to their best, so far.
Navigation
[0] Message Index
[*] Previous page
Go to full version
