SOHC.co.uk Forums > CB750
750 f1 fuel leak
<< < (3/3)
Skoti:
Hi,
thanks for the reply.
The on/off/reserve tap plate is held on with two 4mm screws under which is an '0' ring and a wave washer.
There's a drilled alloy tapered cone valve held into the tap housing with a strong spring.
Google part number 16011-341-004 and you'll see the tap in question.
I'm looking at ebay at the moment for taps in Germany as DS has no stock.
Skoti:
Sorry I gave the wrong part number!
Instead, google part number 16950-341-671 for the fuel tap.
Spitfire:
Just googled that part number and Wemoto came up with one for £28
https://www.wemoto.com/parts/picture/ry-16950-341-671
Skoti:
Thanks Dennis,
but normally I prefer genuine Honda or oem parts if possible as reliability and safety are important for me.
Managed to find a fuel tap in Germany and needle valves in USA, not cheap but you know where you are with genuine Honda stuff (hopefully).
Skoti:
Eventually managed to get the stuff needed to complete the job, hopefully good to go now.
Here's the pics:-
https://photos.app.goo.gl/2MNER31C6ET2Dz2W8
Thanks for all the help and suggestions.
Regards
Skoti
Navigation
[0] Message Index
[*] Previous page
Go to full version
