CB750
1&2 not firing.
Topic: 1&2 not firing. (Read 11358 times)
Andy1976
SOHC Member
'76 Honda CB750F1
1&2 not firing.
August 09, 2009, 02:03:33 AM »
Hi Guys,
I've had to take out my engine to cure an oil leak (More on this later
). Before I removed it I started it up to double check where the leak was coming from. It took ages to get it started and when it did finally cough into life it sounded really rough and sloppy and the throttle response was sluggish.
Anyhow, It's running and I'm on all fours trying to see where this oil is exiting from, when I accidentally banged my forhead on the No.1 header pipe!!
This is when I found out it wasn't running right, as the pipe was stone cold. On further inspection, No.2 was cold too, 3&4 were hot.
I pulled the plugs and they were all black and sooty, (running rich/weak spark i think) but 1&2 were caked in oil, the threads and the tip were covered in it.
Could this be why it's not firing properly or do you think it's something else, IE HT leads pooped, or a bad connection somewhere?
I'm stripping the carbs down again tommorrow to see if owt's blocked up.
Also, it was making a poppin' noise similar to a backfire as if one of the pots was trying to come to life (RPM's increased with every "pop").
What should I be checking to fix this?
Andy
Spitfire
Re: 1&2 not firing.
August 09, 2009, 09:52:23 AM »
Hi Andy, no doubt an expert will be along soon but I'll fill in until they arrive, I take a very simple view on this, 1&4 or 2&3 problems look at the electrics, points, coils, leads, plugs, plug caps, timing.
Any other combination, look at air filter, carbs, exhaust, compression.
A good start is to make sure that the basics are right (points, timing, tappets etc) before becoming fixated on one issue.
Having said that what exhaust have you got fitted, mine has the standard down pipes and a BSM Muffler, as the down pipes are different lengths so the mixture varies from cylinder to cylinder, from too rich to just nice.
The BSM muffler was too restrictive and I was running on 4 then 3 then 2 cylinders due to plug fouling it was driving me nuts until I drilled 4 small holes in the muffler. Now no more fouled plugs.
Hope this helps
Den
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
Re: 1&2 not firing.
August 09, 2009, 10:31:22 AM »
I don't know if true for your model, but on some of the fours there are two feeds from the fuel tap to the carbs. 1&2 or 3&4 not running was always a symptom of fuel starvation in one of them.
Spitfire
Re: 1&2 not firing.
August 09, 2009, 11:52:14 AM »
Steve is right about that, the single pipe from the tap splits in 2, one to 1&2 and the other to 3&4, note also on the F1 that there are sneaky little filters that can only be accessed by removing the float valve set, mine were full of rust.
Den
Andy1976
SOHC Member
'76 Honda CB750F1
Re: 1&2 not firing.
August 09, 2009, 07:19:26 PM »
It seems to be a fuel problem. Also i've drained my fuel tank to fit a new fuel tap,and I can hear what seems to be grit in the tank. What's the best way of getting rid of it? I had a look inside it and can't see any evidence of rusting.
There didn't seem to be anything that resembled a filter either, so should I fit an inline one?
Andy
PS Den, the exhaust system is a Motad 4-1
Last Edit: August 09, 2009, 07:24:00 PM by Andy1976
Spitfire
Re: 1&2 not firing.
August 09, 2009, 08:21:37 PM »
Hi Andy there should be some mesh on the inlet to the petrol tap, plus there are individual filters on each carb.
To check the individual filters remove the carb float bowls, then making sure that you do not mix them up remove the four floats and needle valves (or do it one at a time), then using a 10mm spanner (or socket) remove the needle valve housing, the rust etc will be on the filter and in the carb.
Don't ask me how I know but be very careful doing this as you do not want to break the little legs that the floats hinges off if you use a spanner !
Here's the filter
and this is what was in it
Den
Andy1976
SOHC Member
'76 Honda CB750F1
Re: 1&2 not firing.
September 05, 2009, 06:01:31 PM »
Hi guy's
Thanks for your replies. I've done some checks this aft, got a spark, got fuel getting in (plugs wet), but no bang (only on 4 now).
I'm going to do a compression test tomorrow, what should the readings be?
I've a funny feeling it maybe a head gasket problem.
Andy
Andy1976
SOHC Member
'76 Honda CB750F1
Re: 1&2 not firing.
September 06, 2009, 09:31:28 AM »
Test results No.1 135 psi
No.2 120
No.3 110
No.4 150
This was done on a cold engine as it won't run properly (only on No.4) to get it warm.
Could this be the head gasket blown?
Andy
Spitfire
Re: 1&2 not firing.
September 06, 2009, 01:21:25 PM »
Don't think this would be a head gasket, it's an air cooled motor so the pressure would find it's way out somewhere (breather or external head/barrels) and would be fairly obvious, more likely rings/bores, but the test may not be that accurate if the engine was cold.
You could still be having carb/timing issues, have you checked the valve clearances, they could be causing a lot of your problems including compression.
Den
Andy1976
SOHC Member
'76 Honda CB750F1
Re: 1&2 not firing.
September 07, 2009, 10:31:48 AM »
Hya Den,
I'll double check valve clearances tonight, I also found out that I should've had the throttle wide open when I did the comp test so I'll re do that as well.
Andy
mick
Re: 1&2 not firing.
Reply #10 on:
September 12, 2009, 02:40:06 PM »
Hi Andy how you getting on with 750?
Andy1976
SOHC Member
'76 Honda CB750F1
Re: 1&2 not firing.
Reply #11 on:
September 12, 2009, 06:58:01 PM »
To be honest mate I've not really been near it. It's starting to get me down a bit. I may have an hour or two on it tomorrow once I've got the grass cut. The bike really needs a full strip down and everything cleaned up. It will give me something to do over the winter months I suppose.
Andy
Yoshi823
Biker to the bone...
Re: 1&2 not firing.
Reply #12 on:
November 19, 2009, 08:17:11 PM »
I use a leak down tester to check where the problems are.This 'Sun' item compresses the relevant cylinder to be tested via the spark plug hole with the valves both closed.Then I listen out for escaping air in the airbox (inlet valves),the exhaust pipe end (exhaust valves) or the oil filler cap (on a 550) or a tappet cover on the 750 for there to be heard air escaping meaning a piston ring problem.The leakage is measured using a dial to see how the other cylinders compare.
But in this threads case it sounds more like carbs, as the fine sediment can get past the filters and is more likely to do with leaving the bike on it's sidestand is the reason why it started with cylinders 1 and 2,thwn number 3.
Check the primary jets as well as the air screw drillings.Clean using carb cleaner spray,easily available from Halfords.
As far as the dust in the tank is concerned,I made up an adapter from the house vacuum cleaner and connected it to the tank...and gave it a good shake about.Job done.
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
CB750
1&2 not firing.
