Author Topic: Coil sizes...universal or not?  (Read 3133 times)
Offline Athame57
« on: July 25, 2020, 01:24:49 PM »
There is nothing worse than finding something you've spent a lot of money on does not fit. I went to fit the new coil I bought of Worlds End MC and it is too short to fit into the brackets, also lacking a single wire terminal on the original....or am I to discover the CB400F of 1976 has a different size coils to a CB400F2 of 1978?
1978 CB400F2 named Elen.
Re: Coil sizes...universal or not?
« Reply #1 on: July 25, 2020, 01:31:05 PM »
Only the OEM Coils will fit correctly. Aftermarket could be any size so it's pot luck really.
Offline Athame57
« Reply #2 on: July 25, 2020, 01:36:06 PM »
Hi Julie
There is also this tiny single wire terminal on the original and lacking on this replacement, I don't know what that is. I think I had better send this back to 'Worlds End MC ' and try DSS!
« Reply #3 on: July 25, 2020, 01:37:10 PM »
Hi Julie
Sounds like  a good plan George.
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #4 on: July 25, 2020, 06:03:19 PM »
Hi I bought the DSS aftermarket ones for my 500/4 and very happy. On mine each DSS coil had a + and - feed, and I just had to change the end of one DSS adapter lead on each to a female bullet connector.
The DSS mountings were the right length unlike a set I bought on eBay (and returned)
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline gtmdriver
« Reply #5 on: July 26, 2020, 09:06:09 AM »
No matter where you buy your coils check that they have the correct primary coil resistance. For contact breaker ignition the resistance should be at least 3 ohms. Any less and you risk arcing of the points with rapid contact breaker wear and condenser damage.
« Reply #6 on: July 26, 2020, 10:22:06 AM »
I think 5 ohm is needed for the 500/550 and smaller fours due to lower generator output
