Author Topic: Primary Drive Chain Guide  (Read 4196 times)
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« on: August 04, 2020, 04:28:10 PM »
Just starting to put my engine back together.
Can someone advise which way the primary drive chain guide fits in the lower case?
Outside the two bolts, one end is longer than the other and it has a small hole/depression in it.
Does this go at the bottom, by the oil pan, or the other way round?
Offline ka-ja
  • ken
  • yoshi 460
Re: Primary Drive Chain Guide
« Reply #1 on: August 04, 2020, 07:51:13 PM »
Csml parts diagram shows the same item (141) top and bottom
« Last Edit: August 04, 2020, 07:58:37 PM by ka-ja »
nice bike,nothing in the bank
Offline SeanFD
« Reply #2 on: August 04, 2020, 07:57:22 PM »
Yes there are two of them, but one end is longer - after the bolt hole than the other.
Anyway, I found the answer, from two sources:
Nurse Julie’s rebuild thread on here: http://www.sohc.co.uk/index.php/topic,14049.105.html
And from Kevin on the US site. He posted this amazing pic, which I thought I’d share:
The hole goes towards the sump pan.
Offline ka-ja
  • ken
  • yoshi 460
« Reply #3 on: August 04, 2020, 08:09:38 PM »
Strange one, aladdin's cave parts list says  2 off 23132-333-010  guide, one for the experts to comment on?
« Reply #4 on: August 04, 2020, 08:25:30 PM »
There are 2 fitted Ken, one on the bottom case and one on the top case but that fiché doesn't show the other one in the picture.... Well, not that I can see anyway.
Edit... Just found the other one on the fiché. #141
« Last Edit: August 04, 2020, 08:27:47 PM by Nurse Julie »
Offline SeanFD
« Reply #5 on: August 04, 2020, 10:32:14 PM »
Yes, there are definitely two.
The one in the top case is relatively easy to locate properly as there is a ridge/boss on the case which means it only fits well one way.
In the bottom casE, however, it will sit equally well either way. The problem is that one end - the end with the “dimple” in it – is effectively longer than the other.
In any case the answer seems to be that the “dimple” goes downwards towards the sump.
Offline SeanFD
« Reply #6 on: August 04, 2020, 10:52:57 PM »
So I noted on Nurse Julie’s thread a comment to the effect that: “The primary chain is the original and is knackered.”
I was wondering how you checked it and so looked up my Haynes manual, and guess what I found! Page 36, para 34.2
              “When fitting guides, the incised dot must be at the rear end of the guide” !
There is even a picture!!  :-[
Anyway it didn’t say how to decide of the chain is done, so Julie can you advise?
« Reply #7 on: August 04, 2020, 11:17:36 PM »
Here is my old chain on the left next to the new chain on the right. You can see the old chain has lost a lot of its structure and is sagging. Also, in my mind, there was no point in not changing the chain as I don't plan stripping that engine again and it's a full strip needed to change it, so not prudent or cost effective not changing it during the build. Even if the chain hadn't have been as knackered, I would have changed it anyway.
Offline SeanFD
« Reply #8 on: August 04, 2020, 11:53:10 PM »
Thanks Julie,
Seeing them side by side it’s pretty obvious. I’ll check mine out tomorrow; on visual inspection it looked OK - nothing bent, worn or chewed And it didn’t stretch – but I didn’t think about it sagging like that.
I agree with what you say about not wanting to do it again soon, but it’s always a dilemma; these bikes can last a long time and take a lot of abuse - I’ve just ridden a 750K2 from Zimbabwe to Ireland – so you either decide to replace everything or only stuff that really and clearly needs it.
I started this project on a tidy up and ride basis, so I’m already way past what I started out to do. That in many ways make the decision even more difficult, but if it needs doing, it needs doing.
« Reply #9 on: August 05, 2020, 12:47:51 AM »
The chain is same as a Kawasaki one which can be bought a lot cheaper
Offline SeanFD
« Reply #10 on: August 05, 2020, 10:23:35 AM »
That’s interesting!
Is this the one?
https://www.motorcyclespareparts.eu/en/kawasaki-parts/920571011
£53.50 incl postage vs £152.02 From DSS.
It’s such a a bargain it’d almost make me go for it whatever!  :D
Offline SeanFD
« Reply #11 on: August 21, 2020, 12:35:57 PM »
Well I replaced the primary and cam chains - all or nothing I thought, and repaired the cam chain adjuster hole - that I thought was in good nick on my “new” cases – using the insert from Dennis at Mybikebits:
https://www.ebay.co.uk/itm/Honda-CB400F-stainless-steel-Cam-Chain-Adjuster-Repair-Kit/274371399590?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
He was very good, taking back the bolt I had bought originally and replacing, at new cost of course, it with the repair kit I now needed.
So now I am ready to join the cases, but .... Looking at the parts fiche, it seems there are 4 dowels between the upper and lower cases
The 2 x 323s I have located, but I cannot see where the other two, 322,  should go. I have looked at several pics online and none seem to have these dowels in place.
Can anyone advise if these do, in fact, go between the cases? If so, where exactly, and if not, where do they go?
« Reply #12 on: August 21, 2020, 01:57:46 PM »
The 322's are oilway dowels and go between the top crank case and the barrels. I'll post a pic in a minute. Don't worry about the O ring that I have around the dowel, that's just an upgrade.
« Last Edit: August 21, 2020, 02:03:17 PM by Nurse Julie »
Offline SeanFD
« Reply #13 on: August 21, 2020, 04:18:49 PM »
Great,  thanks Julie.
