Author Topic: Zinc plating  (Read 5788 times)
Offline AndyD
Zinc plating
« on: August 23, 2020, 10:23:38 AM »
Hi,
Any recommendations for zinc plating companies?
I've used a couple and not really happy so far so hoping there may be others worth a go.
I'd seen E Williams mentioned somewhere - maybe a magazine article I think - but any suggestions welcome.
Cheers,
Andy
Re: Zinc plating
« Reply #1 on: August 23, 2020, 10:41:32 AM »
We always use Allenchrome in Pocklington.
https://www.allenchrome.co.uk/
As with all re zincing, the outcome is in your initial prep.
« Last Edit: August 23, 2020, 10:43:05 AM by Nurse Julie »
Re: Zinc plating
« Reply #2 on: August 23, 2020, 10:53:52 AM »
Agree Julie ... as long as you are not in a rush  ;) . Have heard good reports of John Street Platers in Sheffield but not tried them out myself yet.
Offline AndyD
Re: Zinc plating
« Reply #3 on: August 23, 2020, 06:02:04 PM »
Thanks,
I've almost got all the bits ready so will have a ring around next week.
Spent a fair bit of time cleaning parts as I appreciate this is crucial to getting good results.
Degreased everything then gave all the parts a good session in the vibratory tumbler - great bit of kit for cleaning and smoothing brackets and almost anything else. Only area it doesn't cope so well with is the recess in small flanged bolts as I guess the media I use can't easily get right into the edges.
Then spent a happy afternoon with wire wheels and abrasive mops to tidy up as best I can.
Really hoping for good results this time.
Cheers,
Andy
Re: Zinc plating
« Reply #4 on: August 24, 2020, 09:49:11 AM »
I always strip the zinc plating off chemically before taking to Allenchrome and then bead blast with 0/44 beads (the finest glass bead media sold by Vixen)
http://www.sohc.co.uk/index.php/topic,8172.msg53678/topicseen.html#msg53678
« Last Edit: August 24, 2020, 09:56:30 AM by AshimotoK0 »
Re: Zinc plating
« Reply #5 on: August 24, 2020, 06:24:52 PM »
I have a set of four new replica carb to air box clips for my Z1A which are either painted or stoved gloss black. Genuine new ones are unobtainable, as far as I know, and are plated with olive drab zinc. As well as being a very effective anti corrosion finish, to me it makes a big visual difference- yes I should get a life, but it’s something I notice straight away.
I have been in touch with a platers in Nottingham who offer this finish but have a minimum order of £40 plus vat, a bit steep for four  clips, does anyone know any better options?
Re: Zinc plating
« Reply #6 on: August 24, 2020, 06:27:09 PM »
Allenchrome in Pocklington do 'olive drab' but not black. Just tell them how deep colour you need.
Re: Zinc plating
« Reply #7 on: August 24, 2020, 06:47:44 PM »
On original looking Zeds I’ve seen it’s quite dark but with a definite green tinge. I’ll see if I can find a good photo on the interweb.
I’ll send Allenchrome an email, Ash, do they have a minimum job charge do you know?
Re: Zinc plating
« Reply #8 on: August 24, 2020, 08:47:58 PM »
The Zinc coating looks a really neat way to restore the steel bits on carbs & the like - then I'm new to restoration.
Sadly I just do a quick wire brush then paint the rusty steel bits with Hammerite Kurust until it turns either black or gun metal blue. I used to use Trustran back in the 1970's but the brand seems to have gone it was great stuff for bluing your firearms.
Re: Zinc plating
« Reply #9 on: August 24, 2020, 09:50:23 PM »
Not sure Dave  .. worth a call though .. always best to give them a few bits at a time. Colour sound just like I had done to CB500/4 interconnecting clamps on silencers. I also got them to do a really dark olive drab for my 400/4 rear sprocket guard ring thingy
Re: Zinc plating
« Reply #10 on: August 25, 2020, 07:48:09 AM »
I have used Allen street platers in Sheffield loads of times.
Superb job and done in 3 days and you can barter with them on the door  ;D
Offline Seamus
Re: Zinc plating
« Reply #11 on: August 25, 2020, 08:21:35 AM »
Found a small company in Stevenage, (MD Platers). Used a few times for various parts. They do not specialise in bikes but it is run by a couple of bikers.
They do industrial stuff, but will do a basket of bits for a reasonable price (usually cash). I have only had bright zinc done, but the parts came out fine.
All depends on what you want done I guess
Offline AndyD
Re: Zinc plating
« Reply #12 on: August 25, 2020, 03:02:45 PM »
Thanks,
Had a ring around and seemingly everyone is snowed under and on very long timescales.
Has anyone used Vehicle & General in Beds?
Cheers,
Andy
Offline Woodside
Re: Zinc plating
« Reply #13 on: August 25, 2020, 07:45:09 PM »
GBM in alton hants always have a really quick turnaround
Offline Seamus
Re: Zinc plating
« Reply #14 on: August 26, 2020, 08:10:36 AM »
Used them years ago. Good job done, think they now have a long turn around time.
