Author Topic: SETTING FLOAT HEIGHTS  (Read 25556 times)
Offline 3scs
Re: SETTING FLOAT HEIGHTS
« Reply #15 on: August 27, 2020, 06:35:15 PM »
I find a vernier just perfect for the job
(Attachment Link)
that makes it much easier but tell trigg to stand by
« Reply #16 on: November 05, 2020, 06:40:58 AM »
You can cut one yourself out of an old credit card or whatever card.
« Reply #17 on: November 05, 2020, 07:50:21 AM »
I used a Vernier Gauge courtesy of Aldi that I bought from the Man aisle about 5 years ago - I finally got to use it for something useful.
Humans & their Gadgets eh.lol
Offline Greg65
« Reply #18 on: November 05, 2020, 12:25:32 PM »
Absolutely brilliant advice. Any chance that we could have a “How to folder” in the forum and any advice that passes the peer review can be moved into said folder. This will help those of us that never did an honest apprenticeship need some good advice in a ready access folder. No advice  on beer drinking required, cheers.
Keep smiling it makes the management nervous.
Honda CB400 1976
Suzuki GS1000 1978
Offline Athame57
« Reply #19 on: August 20, 2021, 04:21:08 PM »
Hi Julie
The carbs you illustrated aren't from a CB400F are they? I know I'm tired or getting drowsy from fumes but my floats at least appear to be the other way up to the ones you show, I've got a flat surface....they also seem to rest at an angle...my carbs are much cleaner now btw :o
« Last Edit: August 20, 2021, 04:23:22 PM by Athame57 »
1978 CB400F2 named Elen.
« Reply #20 on: August 20, 2021, 04:30:55 PM »
Hi Julie
No George, they were 500 or 550 carbs, not 400. If you have set the floats correctly, as in my guide, the floats shouldn't sit at an angle. With the float tang just touching but not depressing the float needle, they actually sit almost spot on horizontally with the mating face of the carb body where you take the measurement from.
Offline Athame57
« Reply #21 on: August 20, 2021, 05:22:47 PM »
Thanks for this Julie, a bit of a relief, I should have left things alone today, starting something when you're tired isn't helpful!  ;)
