Author Topic: OAP Ted's CB400F2 rebuild - engine not run for about 12 years.  (Read 243297 times)
Re: OAP Ted's CB400F2 rebuild - engine not run for about 12 years.
« Reply #450 on: April 20, 2022, 12:17:33 AM »
Well done Ted. A great feeling of achievement.  🙂 👍
« Reply #451 on: April 20, 2022, 12:29:50 AM »
Get in Ted!!
Well done mate thats absolutely fantastic. So chuffed for you, a thousand bends and a thousand smiles await ;) :)
Your such a trend setting romantic Roo 😊😍
Thanks love ;)
« Reply #452 on: April 28, 2022, 05:07:55 PM »
Aside from some minor fettling my rebuild  project is at an end so if I can I will lock this post.
Thank you everyone here who has helped me through the ups and downs both on the post & with PM's during my journey.
« Last Edit: April 28, 2022, 05:27:55 PM by McCabe-Thiele (Ted) »
« Reply #453 on: May 03, 2022, 12:30:13 PM »
Teds Honda 400 by Macabe Thiele, on Flickr
Teds CB400 by Macabe Thiele, on Flickr
Here is the bike pretty much done unless I decide to get the Tank & side panels painted next winter.
The third mirror was to block up the existing bar end hole plus it was a partly gold mirror for the blind spot!
Offline Rozabikes Tim
« Reply #454 on: May 03, 2022, 04:17:53 PM »
Wow Ted that is crackin. Enjoyed your build thread and your whole attitude to everything. Well done you should be rightly proud.
Offline hondarc166
« Reply #455 on: May 03, 2022, 04:40:41 PM »
well done Ted :)
« Reply #456 on: May 03, 2022, 04:49:11 PM »
Nice one, looks very smart
« Reply #457 on: May 03, 2022, 05:39:19 PM »
Looks lovely Ted.
« Reply #458 on: May 03, 2022, 05:46:20 PM »
Looks absolutely great Ted. You should be justifiably proud. And thanks for taking the time and effort to share your thread with us.
Just one small observation, does that rear brake lever need moving round a few degrees closer to 90 and the rod pushed through a little more.Apologies, but I’m quite fussy about things like that.😌
« Last Edit: May 03, 2022, 07:40:55 PM by Sesman »
Offline heli_madken
« Reply #459 on: May 03, 2022, 06:31:29 PM »
Absolutely gorgeous Ted, you should be very proud well done!
« Reply #460 on: May 03, 2022, 07:42:38 PM »
Just one small observation, does that rear brake lever need moving round a few edges and so the rod can push through a little more.Aplogies, but I’m quite fussy about things like that.😌
Yes the rod is not as far down on the thread as needed. I've actually moved it twice and ended up where it is. The brake shoes are new and I'm pretty sure they will bed in quite quickly as with the thread proud of the bolt you can still rotate the wheel with some effort.
I was trying to maximise the leverage.
« Last Edit: May 03, 2022, 08:08:00 PM by McCabe-Thiele (Ted) »
Offline smoothoperator
« Reply #461 on: May 03, 2022, 07:43:34 PM »
Great result Ted and I've so much enjoyed the ride along with you. Also need to mention all the help with bits and bobs you have done for me. See ya on the road!
Steve
2017 Triumph Bonneville T100
« Reply #462 on: May 03, 2022, 08:12:38 PM »
Yes indeed Crich becons Steve!
« Reply #463 on: May 03, 2022, 10:08:27 PM »
That’s a cracking looking bike Ted, all credit to you.
« Reply #464 on: May 03, 2022, 11:00:28 PM »
Thats a cracking looking bike Ted, you must be super chuffed mate.
A credit to you, well done ;)
