Author Topic: OAP Ted's CB400F2 rebuild - engine not run for about 12 years.  (Read 243363 times)
Re: OAP Ted's CB400F2 rebuild - engine not run for about 12 years.
« Reply #60 on: September 23, 2020, 01:44:14 PM »
It's a strange thing but as I am approaching fitting the tank and getting close to an attempted start up I feel myself slowing down fearing unforeseen issues. I ought instead to be estatic at the prospect - is this normal !!
Oh boy, do I understand that feeling!
Thank goodness I thought I was alone with the unsaid dread!
Offline mattsz
« Reply #61 on: September 23, 2020, 02:17:01 PM »
I understand exactly where it comes from, for me.  Start with a bike I know wasn't running all that well before it sat for 3 years.  Add to that a bunch of repairs and adjustments - to a bike and to systems I'm not too familiar with, and therefore don't have a lot of confidence about.  I hope for the best, but assume things will go wrong...
« Reply #62 on: September 24, 2020, 05:00:11 PM »
Another step closer today - re-fitted old Petcock with new tank strainer used the old seal but have the two that DS supplied - petrol tank back on the bike - 4 Litres of new Super Unleaded tap into Reserve position petrol filled the little in-line filter all looked okay for a minute or so then petrol started coming out of two of the overflow pipes. Big curse to myself !
Walked away wishing I had checked the carbs with fuel before I re-fitted them to the bike had a moan with a mate who said - have you tried a gentle tap on the carbs incase the floats are just a bit stuck as they were completely dry. Did just that followed by shaking the bike from side to side - fuel back into reserve no sign of any more fuel from overflow pipes. I've given it a good 5 minutes and no more fuel out of any of the overflows. I feel happy that's good enough for a planned initial start up.
I've checked for spark - nice visible spark at the old dirty spark plugs - I am now ready to check the static timing tomorrow morning then its new plugs in place and see if she will run. The new plugs that came with the bike are NGK D8EA as are the old ones that were fitted.
Fingers crossed for tomorrows start up attempt !! :)
« Last Edit: September 24, 2020, 05:08:46 PM by Macabethiele »
« Reply #63 on: September 24, 2020, 05:29:03 PM »
Ooooh, how exciting, good luck 🤞🤞🤞
Offline mattsz
« Reply #64 on: September 24, 2020, 09:41:59 PM »
Offline Grumpyfck
  • Grumpy old fella
« Reply #65 on: September 24, 2020, 10:36:52 PM »
This is better than eastenders, good luck.
Longest midlife crisis known to man.
Offline heli_madken
« Reply #66 on: September 24, 2020, 11:18:21 PM »
Good luck, hope it goes well
« Reply #67 on: September 25, 2020, 11:34:42 AM »
Set the static timing this morning took me about an hour to get it all done plus 30 mins spent making a decent loom connector & test lamp to set 1&4 then 2&3.
Cranked her over having got the oil light out first with no plugs fitted - plugs in after a fair bit of popping & banging she started to fire - more choke less throttle and away she went. Only a brief video but I am ecstatic !!
Hope the brief video works.
https://www.youtube.com/watch?v=_XqxDCtCqKg&feature=youtu.be
« Reply #68 on: September 25, 2020, 11:57:01 AM »
Fantastic Ted, brilliant, well done.
Offline mattsz
« Reply #69 on: September 25, 2020, 11:58:16 AM »
That's excellent!
The video works - it's sideways, but that's ok, the bike isn't moving anyway! ;D
« Reply #70 on: September 25, 2020, 12:01:25 PM »
Good news,  it's nice when you get them going.
Unfortunately for me it starts that video trail on the tube with the suggestion side bar,  and off into all sort of interesting stuff  :D
« Reply #71 on: September 25, 2020, 02:02:39 PM »
« Reply #72 on: September 25, 2020, 02:08:55 PM »
It sounds even better the right way up.
« Reply #73 on: September 25, 2020, 03:45:44 PM »
Well done. It's a great feeling when they run. 👍
Offline Grumpyfck
  • Grumpy old fella
« Reply #74 on: September 25, 2020, 05:38:55 PM »
Now I am impatient for mine.
