SOHC.co.uk Forums > CB350/400
Why can't you have rusty petrol tank shot or bead blasted ?
<< < (5/5)
Athame57:
--- Quote from: Rob62 on September 06, 2020, 12:25:04 PM ---Evaporust breaks the chemical bond between iron and oxygen, it doesn’t turn the metal black or any other colour... The only thing you must do is rinse thoroughly with water and then (for tanks) immediately dry and slosh some 2t and petrol in there to prevent flash rusting, which will occur whatever technique you use if you leave untreated after rinsing.
--- End quote ---
What is 2t?  ???
robvangulik:
Two-stroke oil.
mattsz:
--- Quote from: Macabethiele on September 06, 2020, 02:19:27 PM ---The black colouration after using Evaporust was what I read on some reviews.
--- End quote ---
Evaporust does not leave a coating.  I used it in my tank, which was in pretty good shape, but not perfect.  It did a really nice job.  After rinsing and drying, I tossed in a pint or so of kerosene (paraffin) and shook it all around to completely coat the inside, then drained all I could.  It kept rust from reforming for the last 4 months...
the-chauffeur:
I've never been able to get hold of Evaporust when I needed it, so I used a rust converter solution that's closer to home.
If you're not in any hurry, mix up some of that stuff, leave it in the tank for a few days and agitate periodically.  I'm sure the instructions claim it acts faster, but my experience is that the longer you leave it (within reason) the better.  If the rust is only surface deep, it'll clean it all out.  Any heavier and it'll work, but for piece of mind you'll probably want to go the electrolysis route as well, just in case.
The difference between the chemical and mechanical methods are that the chemical options convert what's already there; in that sense, they're non-reductive (not the right word but you get what I mean).  With mechanical methods like gravel, you're taking stuff off.  Personally, I'd go with the conversion routes esp. with the low impact converter solutions because they tend to be very gentle.
Rob62:
https://www.thompsonsltd.co.uk/qevp5l-evapo-rust-5l-rust-remover-liquid-solution-removes-metal-oxides-water-soluble.html
Navigation
[0] Message Index
[*] Previous page
Go to full version
