Author Topic: Greetings from Manchester on Sea  (Read 3896 times)
Offline Primus
« on: September 23, 2020, 04:15:54 PM »
Hi.  Paul here from Manchester. 61 years young.  I joined the other SOHC forum out of courtesy as I had used it on several occasions to assist with issues on my 750K7. I own a Harley Sportster 1200, a BSA B40, a Honda ST1100 and a CB750K7 with which I am currently chasing oil leaks.  I can't believe that the tacho oil seal had 2 seals in it and the lower one was like iron so I was convinced that I wasn't fitting the new one correctly. Measuring the depth ot the cavity proved that something was still in there and using the time honoured woodscrew trick worked.  I have recently re gasketted the gear change and alternator covers as well.  It is not only brit bikes that leak!  I hope to have some input.
Paul
All ashore that's going ashore
Re: Greetings from Manchester on Sea
« Reply #1 on: September 23, 2020, 04:32:57 PM »
Hondas only leak to prove their superiority! Or when assembled wrong
« Reply #2 on: September 23, 2020, 06:10:38 PM »
Welcome to the Forum Paul.
Offline Phil Ward (RIP)
« Reply #3 on: September 23, 2020, 07:35:09 PM »
Welcome to the forum Paul - enjoy the forum
« Reply #4 on: September 23, 2020, 08:16:10 PM »
Welcome to the forum Paul.
We've seen this engine on here,  examples of, with the crankcase breather plumbed together so they don't vent at all, resulting in sporadic leaks. Worth checking to see if anything like that is compromised and causing you problems.
Offline Primus
« Reply #5 on: September 24, 2020, 03:54:20 PM »
Thanks for the warm welcome folks.  I'll confiirm that the breather pipes are correct K2-K6.  I'm not to far from you philward. I'm in Astley so not a pie eater.
Paul
Offline Moorey
« Reply #6 on: September 24, 2020, 06:35:16 PM »
Welcome to the forum and enjoy.
« Reply #7 on: September 24, 2020, 09:19:37 PM »
Welcome to the 400four forum.
There's a transvestite up by where Philward lives.
He's got a Wigan address.
« Reply #8 on: September 24, 2020, 09:45:21 PM »
Well above my head that Mike?
« Reply #9 on: September 24, 2020, 09:47:56 PM »
Paul
I'm  in Winstanley Paul so just down the East Lancs
« Reply #10 on: September 25, 2020, 10:00:10 AM »
Got it now Mike - Alan (MCTID) explained it to me, age is a terrible thing!
