SOHC.co.uk Forums > CB350/400
Oops or **** it! Rear wheel re-spoke update
<< < (5/5)
waffey:
sorry to jump in as well. I'm looking to rebuild my rear wheel soon.
I used the front wheel rim and spokes from WEMOTO. Quality seems to be good but they dont have the rear.
r
Is it only DSS that have stock ear rims or can I source them else where?
billdn:
Well that was easier with the DID rim than the other ones, I've managed to get around 1mm run out on the lateral (side to side ) which I feel is acceptable but I'm not sure on the radial -currently about 1mm measured with a feeler gauge between pointer and rim edge- looks okay to me but should it be lower.?
taysidedragon:
--- Quote from: billdn on October 16, 2020, 10:08:30 AM ---Well that was easier with the DID rim than the other ones, I've managed to get around 1mm run out on the lateral (side to side ) which I feel is acceptable but I'm not sure on the radial -currently about 1mm measured with a feeler gauge between pointer and rim edge- looks okay to me but should it be lower.?
--- End quote ---
I think that's within tolerance, but try and get it closer if you can.
Bryanj:
Honda's (and mot) tolerance is 3mm for each
billdn:
BryanJ - thanks for that, well under 3mm which does seem an awful lot but finished at 1.5mm for both so good enough for Jazz :)
Navigation
[0] Message Index
[*] Previous page
Go to full version
