SOHC.co.uk Forums > CB750
CB750K2 Charging problem
Trigger:
It looks like all you need is a feed from the battery to the loom ;)
I have had time to look at the set up on one of my K2's and the red/white feeds the loom and the red with the spade goes to the fuse box .
Bryanj:
You dont need to buy the new Honda lead just make up a short lead with a ring terminal on one end to bolt to solenoid along with the main battery one and the appropriate bullet one the other end
Bigbadbob:
Thanks for all your help, I connected the red white wire directly to the battery and the bike is producing about 14.5 to 15.50 volts maximum at varying revs.
This same RED/WHITE wire was producing around 50V at 3000RPM when not connected to anything.
I've now just got to buy a new battery solenoid cable but I'll most probably do the modification BryanJ suggested.
Can someone advise if I can leave things as they or should I try and adjust my voltage regulator or even replace it, I can see Lobo's post and my voltage at the battery appears to be on the high side?
Bryanj:
As long as you buy a lead/acid battery and not one of these new fangled ones it will be fine, charging voltage will probably drop with a decent battery
Bigbadbob:
All sorted, many thanks all of you. Just need some weather suitable to enjoy the ride :)
Navigation
[0] Message Index
[*] Previous page
Go to full version
