Author Topic: Castellated Clutch Nut - how tight ?  (Read 3190 times)
« on: October 09, 2020, 07:52:01 PM »
I've been looking for a torque setting for the above nut - does 30Lb-ft sound about right?
Offline Deano400
Re: Castellated Clutch Nut - how tight ?
« Reply #1 on: October 09, 2020, 10:30:18 PM »
Can't say it's 100% but one of the manuals I have has these torque settings:
So 30 looks ok.
« Reply #2 on: October 10, 2020, 03:07:18 AM »
(Attachment Link)
So 30 looks ok.
Thanks Deano one of my manuals does not seem to say or calls it something else the other had a figure like your chart but it seemed a tad on the low side - I guess I'm used to torque figures on cars that tend to be somewhat higher. Also its out of range on my old Britool torque wrench.
« Reply #3 on: October 10, 2020, 07:57:52 AM »
Start at 30 and if the locking tabs are not lined up to bend over in place than, you tighten until a tab has a home to sit in  ;)
Offline bobv7
« Reply #4 on: October 10, 2020, 01:08:50 PM »
This is the official work shop tool from the 1970's which may give a clue to how much torque is needed.
« Reply #5 on: October 10, 2020, 01:44:54 PM »
Thanks guys that very helpful. I'll nip the nut up when my new torque wrench arrives my old Britool Torque wrench is a good 50 years old but the scale starts at over 30 lb ft so decided to treat myself to a lower range wrench that I will need for cylinder head bolts etc.
I had the Britool recalibrated a good 30 years ago when it was fitted with a new spring - I always undo the adjuster so there is no tension at rest. Sadly I tend to use impact torque sticks on our 4 wheeled vehicles - its just so easy!
