Author Topic: Engine Covers etc oven bake at what temperature / time etc ?  (Read 5791 times)
« on: October 15, 2020, 05:57:15 PM »
I've read about using SIMVHT31D paint with recommendations to bake it on in the oven.
Just need to know the cooking instructions - is it put in oven when wet (fire hazard?)or touch dry ?
In a preheated Fan Oven - what temperature is needed - for how long ?
Re: Engine Covers etc oven bake at what temperature / time etc ?
« Reply #1 on: October 15, 2020, 06:07:59 PM »
It tells you on the tin  ;)
After spray, leave in a warm temp for at least 24hrs. Then place in a oven and increase temp slowly to 200c and once the temp is up, leave at 200c for a hour and half.
« Reply #2 on: October 15, 2020, 06:26:16 PM »
Thanks Trigger can hasn't arrived yet.
« Reply #3 on: October 15, 2020, 07:14:28 PM »
What engine parts are you painting ? Make sure they are free of any oil, inside and out. Oil stains on the inside of the cases smoke, and turn the paint. Oil or any grease on the painted area will bubble and lift paint. Prep is the key to any good paint finish  ;)
Offline SteveW
« Reply #4 on: October 15, 2020, 07:25:33 PM »
Sorry to hijack this thread but i'm planning a top end rebuild on the 550 over the winter to cure the oil leaks.
I'm not going to open the bottom end but want to clean it up and paint it.
What are my options when it comes to curing the paint on the bottom half?
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
« Reply #5 on: October 15, 2020, 07:34:25 PM »
Your only real option is to let the heat of the engine cure it. But, the paint will not be very robust or as hard wearing and can chip. I do know someone that used a heat gun but the outcome was quite dismall, the finish was patchy and it wasn't as resistant as it should be to petrol etc.
Offline SteveW
« Reply #6 on: October 15, 2020, 08:12:30 PM »
Thanks Julie.
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #7 on: October 15, 2020, 11:04:11 PM »
At present I'm planning to paint the Clutch Cover & the front sprocket cover. BIL is giving me some old formula Nitromors paint stripper - I have cleaned the insides with Gunk at present to remove the light brown oil staining.
« Reply #8 on: October 16, 2020, 07:43:27 AM »
I find that giving them a per-bake also helps and a good wipe down of the painted faces with a proper paint shop de-greaser  ;)
Paint them where it is warm and not outside on a very cold damp day.
« Reply #9 on: October 16, 2020, 08:50:21 AM »
If you are planning to cure the paint in the kitchen oven you need to ensure you have treated your o/h (and her best friend) to a luxury Spa weekend away at the same time to allow the fumes to dissipate before she arrives home. Oh, and you give her your credit card for a shopping trip whilst she's away just to be on the safe side!
Offline Deano400
« Reply #10 on: October 16, 2020, 08:57:17 AM »
Be carful curing barrels. I know someone who put them in the oven to cure. Opened the oven at the end and the barrel had dropped off the liners.
« Reply #11 on: October 16, 2020, 09:32:43 AM »
Fully understood I have had 43 years of marriage to break me in! ;D ;D
« Reply #12 on: October 16, 2020, 10:23:35 AM »
Offline SteveW
« Reply #13 on: October 16, 2020, 01:06:12 PM »
Anyone cured their engine in a gas barbecue?
Mine has a temp gauge on it.
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #14 on: October 16, 2020, 03:16:44 PM »
Yea Alen Millyard  does it all of the time in his Youtube videos  :)
