Author Topic: Top yoke washers.  (Read 3108 times)
Top yoke washers.
« on: October 16, 2020, 12:01:44 PM »
Hi, sorry this is probably old ground but can anybody confirm the thickness of the d washers in the top yoke clamp?
Also is their just one size for all models that require these?
Re: Top yoke washers.
« Reply #1 on: October 16, 2020, 12:15:12 PM »
Here's my drawing ..  'Checked by'  S.B. Devotion ;D ;D
Top Yoke Spacer P/N 53235-300-000  Dimensions taken from my 3/71 CB500K0 but same P/N as CB750
« Reply #2 on: October 16, 2020, 12:56:09 PM »
Thanks Ash, most helpful. Will probably have to fabricate something as no longer available.
« Last Edit: October 16, 2020, 01:07:05 PM by Johnny4428 »
« Reply #3 on: October 16, 2020, 01:19:50 PM »
If your top yoke bolt holes are 7mm with 7mm bolts then, you don't require them  ;)
And they are ready available.
« Last Edit: October 16, 2020, 01:21:50 PM by Trigger »
« Reply #4 on: October 16, 2020, 01:52:13 PM »
So without me getting the top yoke out of storage for my 500k2, does my model need them Graham? (I know you will know from the top of your head!).
« Reply #5 on: October 16, 2020, 01:58:41 PM »
Relaying messages here 🙄🙄🙄He hasn't got hasn't got a clue Phil, he's never had a 500/4 K2. He says you need to check to make sure your top yolk is a K2 and if it is, measure the bolt size or the hole size.
« Reply #6 on: October 16, 2020, 02:08:13 PM »
Thanks Julie - I'll check.
« Reply #7 on: October 16, 2020, 04:31:41 PM »
Dunno if this correct.
[ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
« Last Edit: October 16, 2020, 04:34:04 PM by AshimotoK0 »
« Reply #8 on: October 16, 2020, 04:38:54 PM »
The top yoke was modified at some point to have smaller holes and bolts with no D washers and the later type was the supplied as a spare for all of them from a date i cant remember so you need to check the size of the hole and the bolt not matter what year the bike is
« Reply #9 on: October 16, 2020, 05:19:17 PM »
Don't believe everything you read Ash and how do you know that it still has a early K2 yoke fitted  ;)
« Reply #10 on: October 16, 2020, 06:04:30 PM »
It’s M8 Bolt’s and the previous owner tried the top yoke with no washers. You can guess the result of that.😡
« Reply #11 on: October 17, 2020, 09:22:08 AM »
'Cos I am a  psychic and it was an 8mm bolt   ;D ;D
Offline Seabeowner
« Reply #12 on: October 17, 2020, 09:42:52 AM »
I used a couple of washers that that were for the crankcase main bearings off a 500 and cut the edge off as a temporary measure. They are about 2.4mm thick. Can't remember head washers may be the same.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #13 on: October 17, 2020, 01:42:18 PM »
Thanks Phil, I will be raking through boxes of bits and pieces over the weekend.
