Author Topic: Which wiring loom?  (Read 3094 times)
Offline rustywheels
Which wiring loom?
« on: November 04, 2020, 05:23:39 PM »
The wiring loom on my 400 is a little worse for wear, and thinking of replacing it.  I see that DS has one, and also Legend Motorcycles on ebay.  Any thoughts on preference?  I like that the Legend one is made with 'Love'  :)
https://www.ebay.co.uk/itm/NEW-Honda-CB400F-75-77-Main-Wiring-Harness-Loom/124311662990?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160811114145%26meid%3D628cb3d568da40db98c94445e230bdfe%26pid%3D100667%26rk%3D8%26rkt%3D8%26mehot%3Dnone%26sd%3D283983275391%26itm%3D124311662990%26pmt%3D0%26noa%3D1%26pg%3D2334524%26brand%3DUnbranded%2FGeneric&_trksid=p2334524.c100667.m2042
I feel I give quite a bit of my cash to DS, so good to share it around if I can.
1977 Honda CB400F
1978 Yamaha XT500
1989 Mazda MX5
Re: Which wiring loom?
« Reply #1 on: November 04, 2020, 05:32:32 PM »
I have no experience of either but I wish the company that makes them would use the correct colour wires 🙄🙄🙄🙄
« Reply #2 on: November 04, 2020, 05:38:03 PM »
I've used 3 of DS's looms for 3 separate 750's with no issues. Might not be exactly as per original but all the connections fit and go to the right places!
Offline rustywheels
« Reply #3 on: November 04, 2020, 06:39:06 PM »
You would have thought that was a given  :-\
1977 Honda CB400F
1978 Yamaha XT500
1989 Mazda MX5
Offline Athame57
« Reply #4 on: November 04, 2020, 07:02:08 PM »
I have got one from DSS, mine was fitted for me so I can only say I got into trouble with colour codes when I replaced my left hand switch gear recently, I had a new aftermarket one on already, broken courtesy me and thinking my stand was out when it wasn't.  I'm still at my wits end with a zunched out starter motor and no tail light at this stage but otherwise my loom has been fine and so are a few other electrical bits I got from DSS...no more stopping because there was nearly a fire under my left side panel.
1978 CB400F2 named Elen.
« Reply #5 on: November 05, 2020, 12:13:57 PM »
I have used these a few times and been spot on.
https://www.electrexworld.co.uk/acatalog/Wiring-Harnesses.html
« Reply #6 on: November 07, 2020, 03:14:34 AM »
« Reply #7 on: November 07, 2020, 05:44:05 PM »
Are they the same colors as the original?
