SOHC.co.uk Forums > CB500/550
Front brake
Bryanj:
As long as it is capped its fine
bobv7:
Makes a change to have some good news. Thanks for that and the cap is well screwed on. :D
Seabeowner:
As part of servicing lots of car manufacturers specify changing the fluid every two, three or four years. A real money spinner for garages.
Bryanj:
It is a good idea to change every few years as in a car with vent holes in the master ot does absorb water then if you need to brake a lot the fluid gets hot enough for the water to boil off causing vapour lock and lost brakes
McCabe-Thiele (Ted):
--- Quote from: Bryanj on November 05, 2020, 05:20:20 PM ---
Unless you can guarantee to get every last tiny bit of old fluid out dont use dot5.
--- End quote ---
That's why I am a big fan of dot 5.1 it's not overly expensive with lower hygroscopic spec plus it mixes with everything except dot 5.0.
Navigation
[0] Message Index
[*] Previous page
Go to full version
