Author Topic: CB400F2 Chain Guard 40510-377-000  (Read 2578 times)
« on: November 06, 2020, 11:58:38 PM »
The chain guard on my bike has been painted black at some time and although it does have a small crease near the end it is quite small so I could go down the re-chrome route if a new one is not available from the UK.
DS & Bertrums are no stock or discontinued aside from CMS is there anyone else that supply replicas?
chain guard by Teddy Bagshaw, on Flickr
Offline Athame57
Re: CB400F2 Chain Guard 40510-377-000
« Reply #1 on: November 07, 2020, 12:29:11 PM »
Is the small crease you speak of the depression just above the screw hole? It is actually supposed to be there even though it looks like an accident!
1978 CB400F2 named Elen.
« Reply #2 on: November 07, 2020, 12:47:44 PM »
That recess is meant to be there, if it wasn't, the bottom of the shock would not fit.
« Last Edit: November 07, 2020, 12:49:26 PM by Nurse Julie »
« Reply #3 on: November 07, 2020, 05:42:46 PM »
No it's a small crease at right angles to the chain guard length quite close to the rear end. You can't see it in my poor photo.
« Reply #4 on: November 07, 2020, 05:53:14 PM »
Needs a dammed good "planishing" Sir,  prior to rechrome.  :)
« Reply #5 on: November 07, 2020, 06:24:02 PM »
With a bit of luck the chrome's might be able to do that - I would probably make it worse. I have previous for such things.
