Author Topic: Removing the rocker shafts 400/4  (Read 4688 times)
« on: November 18, 2020, 03:55:58 PM »
My manual states a suitable 10 mm should be used to withdraw the rocker shafts.
Firstly are all 10mm bolts the same thread or is there a fine & coarse option? I have as yet to buy a selection of useful metric bolts so any suggestion as to suitable length is welcome.
Re: Removing the rocker shafts 400/4
« Reply #1 on: November 18, 2020, 05:40:34 PM »
There are 3 different pitches on 10 mmbut that sounds a bit bit are you sure its not 6mm (10mm spanner)
« Reply #2 on: November 18, 2020, 07:24:48 PM »
I'm going off the Haynes Manual kit shows the 550 as 6mm.
« Reply #3 on: November 18, 2020, 07:59:34 PM »
if its a 400/4 any m10 bolt out the engine will fit i use them every time
[/quote
OK but as I don't understand metric is that a fine thread?
« Reply #4 on: November 18, 2020, 08:46:24 PM »
I've removed the first on by putting a close sized bolt in the hole and pushing it to one side so the threads touch - it pulled out with no effort!
Offline ttr400
    • CB400F special machined parts
« Reply #5 on: November 19, 2020, 04:42:18 AM »
Bolt size is M10x1.25
Kevin
If you are addicted to the little CB400F then you might want to check out my website.
www.ttr400.com
