Author Topic: Hi  (Read 6296 times)
Re: Hi
« Reply #15 on: November 22, 2020, 07:59:18 PM »
I would suggest stripping the bottom end then you can change the primary chains, tensioner etc etc and giving it a good assessment overall. Would be a shame to get it all back together and in the frame and then have to remove it all again if there is a problem you weren't aware of.
Offline Brett72
Re: Hi
« Reply #16 on: November 22, 2020, 08:06:00 PM »
I think you are right Julie, i am not in a rush so might as well do it properly. Think i need a bigger space in my garage though  ;D
Offline Phil Ward (RIP)
Re: Hi
« Reply #17 on: November 22, 2020, 08:09:10 PM »
I agree with Julie, tensioner rubber parts will deteriate even if low mileage so while out of frame, I'd strip bottom end
Re: Hi
« Reply #18 on: November 22, 2020, 08:13:32 PM »
May be worth you starting a new thread in the 750 section Brett as many people will look in there for references to  engine rebuilds.
Offline Brett72
Re: Hi
« Reply #19 on: November 22, 2020, 08:18:57 PM »
Have just done that called CB750 K5/6/7 :) In the projects section
« Last Edit: November 22, 2020, 08:20:58 PM by Brett72 »
Re: Hi
« Reply #20 on: November 22, 2020, 08:37:31 PM »
Great.
Offline Athame57
Re: Hi
« Reply #21 on: November 23, 2020, 02:44:12 AM »
Hi Brett
Welcome here, good luck with the bike!  :D
1978 CB400F2 named Elen.
