Author Topic: Pistons  (Read 5179 times)
Offline 4wDaz
Pistons
« on: November 23, 2020, 05:18:50 PM »
Hi does anyone have a recommendation for new pistons ? My engine needs a rebuild and a rebore, I’ve looked at Silvers website but is there anything better available ? Thanks
Genuine And Aftermarket Motorcycle Parts Supplier
Re: Pistons
« Reply #1 on: November 23, 2020, 05:31:23 PM »
Cruzinimage do excellent piston / ring kits.
Offline TrickyMicky
Re: Pistons
« Reply #2 on: November 23, 2020, 07:20:47 PM »
If you really want to push the boat out, there is a set of plus 50's on Ebay, genuine unused Honda parts, includes rings, gudgeon pins and circlips. But, you might want to take out a mortgage, £300.
Offline 4wDaz
Re: Pistons
« Reply #3 on: November 23, 2020, 11:13:50 PM »
Just had a look at there web site, have you used them before ?
Offline 4wDaz
Re: Pistons
« Reply #4 on: November 23, 2020, 11:14:35 PM »
No thanks  :D
Re: Pistons
« Reply #5 on: November 23, 2020, 11:16:31 PM »
Yes, we use their piston / ring kits regularly on CB SOHC/4. I also used them on my 400/4 engine overhaul.
Offline 4wDaz
Re: Pistons
« Reply #6 on: November 24, 2020, 07:42:26 PM »
Thanks, ill give them a go  :)
Offline 4wDaz
Re: Pistons
« Reply #7 on: May 13, 2021, 10:43:54 AM »
After a long delay I'm ready to have the rebore done, the engineer has asked me to provide the standard bore size (51mm, 2.0079) and the Cruzinimage piston clearance ? I remember reading a post by Julie which said what Cruzinimage piston clearance was but I can't find it now. Thanks
Re: Pistons
« Reply #8 on: May 13, 2021, 11:07:53 AM »
Piston / bore clearance of 1 thou inch by n Cruzinimage pistons.
Offline 4wDaz
Re: Pistons
« Reply #9 on: May 13, 2021, 02:12:19 PM »
Thank you  :)
Re: Pistons
« Reply #10 on: May 13, 2021, 04:47:55 PM »
Make sure he understands that is 1 thou total and not per inch and if he insists it will sieze so needs more take it elswhere
Offline 4wDaz
Re: Pistons
« Reply #11 on: May 15, 2021, 05:45:48 PM »
Ok thanks ill mention it, he comes highly recommended, he does all the rebores for a mate of mine who repairs and restores vintage bikes for a living  :)
