Author Topic: Oil Filter Seal  (Read 13173 times)
Offline JonnyB
    • BatchScan
Oil Filter Seal
« on: November 09, 2005, 03:15:59 PM »
Is it possible to buy the seal for the oil filter housing. I bought a filter expecting a seal but no joy.
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
John
https://batchscan.co.uk/
jimshea
Re:Oil Filter Seal
« Reply #1 on: November 09, 2005, 03:27:41 PM »
John,
I just changed the oil filter on my F1 and I didn't see a seal! would it have been stuck to the case?
Jim.
Offline JonnyB
    • BatchScan
Re:Oil Filter Seal
« Reply #2 on: November 09, 2005, 03:36:21 PM »
There should be one on the inside rim of the filter cover. It must have been lost when I cleaned it.
John
jimshea
Re:Oil Filter Seal
« Reply #3 on: November 09, 2005, 04:02:03 PM »
Oh bug**r! I now don't know if I have one or not, I don,t remeber seeing it. I assume I would be leaking a lot of oil if it wasn't there?
Jim.
Online SteveD CB500K0
Re:Oil Filter Seal
« Reply #4 on: November 09, 2005, 04:55:55 PM »
If you buy the Honda filters they come with an o-ring.
I just bought a pack of 5 from David Silver and they don't (guess you get what you pay for)
I'll bet Bryan Jones has some in his cupboard for the price of a pint!
Offline JonnyB
    • BatchScan
Re:Oil Filter Seal
« Reply #5 on: November 09, 2005, 07:12:30 PM »
I suppose then, the answer to the question \"Would you like and original or pattern filter, sir?\" is \"Yes, (I don't mind paying
John
Re:Oil Filter Seal
« Reply #6 on: November 10, 2005, 09:30:30 AM »
You should call DS and make sure that the \"original\" filters are in fact OEM and include the o-ring.
I'm not doubting them (I am actually...) but these are consumables and NOS can't possibly have survived this long. If they have, what sort of condition are they in?
I would guess that they're OEM \"as made for Honda\"
Re:Oil Filter Seal
« Reply #7 on: November 10, 2005, 09:39:43 PM »
Wemoto sell them with or without o-rings at the same price (
jimshea
Re:Oil Filter Seal
« Reply #8 on: November 11, 2005, 07:57:48 AM »
Does the seal come already attached to the base of the DS supplied filter? I did not see one on the one I fitted a week or so ago!
Jim.
Offline JonnyB
    • BatchScan
Re:Oil Filter Seal
« Reply #9 on: November 11, 2005, 08:53:42 AM »
If you look here, http://www.honda-sohc.co.uk/index.php?option=com_wrapper&Itemid=161 on page 13 the seal neaest the filter normally comes with a new one (mine did) the big o-ring sits inside the recess on the housing and the small o-ring seal the bolt. these I think only come with the OEM filters, and the hi-flo filters from Wemoto (looking at the pictures).
BTW. when you changed yours did you have the spring, I don't have one. :unsure:
John
jimshea
Re:Oil Filter Seal
« Reply #10 on: November 11, 2005, 05:38:48 PM »
Yes mine had a spring, which I am told is essential, however I did not have the spring seat(washer) which I am told doesn't really matter. DSS sells both.
Washer part # 15414-300-000
Spring part # 15415-300-000
Offline JonnyB
    • BatchScan
Re:Oil Filter Seal
« Reply #11 on: November 11, 2005, 05:45:37 PM »
Mmmmmmm, About what size is this spring, I have a couple of boxes of nut, bolts and springs, the F has been in bits for so long, plus two house moves it may be laying around somewhere.
John
jimshea
Re:Oil Filter Seal
« Reply #12 on: November 11, 2005, 07:22:07 PM »
Good Q. It's about 1.5\" wide and about 3+\" long?
