SOHC.co.uk Forums > CB500/550
CB500 K1 Front wheel
<< < (6/6)
Kelly E:
Those look like adjustable pre-load caps or they just made it easy to change fluid in the forks.
Charlie J:
Problem is the bolts are in blind holes so you couldn't get any fluid in through them!
Charlie J:
--- Quote from: Oddjob on January 01, 2021, 08:56:11 PM ---I did a conversion like that to thread an air valve into. Was experimenting with air assisted forks.
--- End quote ---
That could well be what the threaded holes were for but the job never got finished. Perhaps the PO didn’t have a long enough tap.
ST1100:
--- Quote from: Charlie J on January 01, 2021, 04:21:27 PM ---But just to add to the conundrum, does anyone have any idea what the bolts threaded into the top of the forks might be for? Somebody has gone to the trouble of cutting a thread in a blind hole to insert the bolts. I can’t think of any purpose they might serve.
(Attachment Link)
--- End quote ---
Got some 2-piece sport handlebars/clip-ons that would fit there...
They clamp on the tube, "ears" at the top get bolted to the fork-caps...
<edit>
found them, took pics...
Bryanj:
Those look a bit like Dunstalls
Navigation
[0] Message Index
[*] Previous page
Go to full version
