Author Topic: Steering Yoke Ball Bearings 400/four  (Read 4677 times)
« on: February 07, 2021, 09:10:06 PM »
Does anyone know if the steering race ball bearings are a standard size or can you buy a complete kit DS want 29pence each for them?
Re: Steering Yoke Ball Bearings 400/four
« Reply #1 on: February 07, 2021, 09:30:22 PM »
Check out the local industrial estate for bearing supplies.
They should have loose balls.
If you will pardon the expression
Get them to mic them for size
« Reply #2 on: February 07, 2021, 09:41:17 PM »
Also try push bike shops.
Offline TrickyMicky
« Reply #3 on: February 07, 2021, 11:13:57 PM »
Please forgive me if I've missed something obvious, but if you've gone to all the trouble of dismantling the front end, surely it's a lot less hassle just to replace the whole lot with a set of taper roller bearings. From the way I've read it, it gives the ipression that you are leaving the old races in place and just renewing the balls?
« Reply #4 on: February 07, 2021, 11:34:01 PM »
If taper bearings were a straight fit that would be great but from what I have read it isn't and you end up with not much thread when you fit the top nut unless someone has made a conversion kit. Naturally I would replace the races if badly worn. It appears the top race bearings were more corroded on mine. Does anyone know the size as a don't have a micrometer as yet.
« Last Edit: February 07, 2021, 11:36:33 PM by Macabethiele (Ted) »
« Reply #5 on: February 08, 2021, 09:57:44 AM »
I understand most of the wear force sits on the lower bearing so am wondering if a hybrid arrangement  is more practical - taper bearing at the bottom plain at the top ?
Then again for my likely low summer mileage perhaps original is more straight forward ?
« Reply #6 on: February 08, 2021, 11:49:00 AM »
I found the problem is if you use a thin spacer the bottom yoke came up against the frame and thinest spacer i found was 1mm.
Possibly you could grind some off the frame at bottom but not tried that
« Reply #7 on: February 08, 2021, 12:11:32 PM »
According to the parts diagram and the manual there are 37 ball bearings, 19 in the top and 18 in the bottom, they are called #8 ball bearings which according to the web means 1/4".
Like these.
https://simplybearings.co.uk/shop/product_info.php?products_id=38916&vat_inc=true&gclid=Cj0KCQiA34OBBhCcARIsAG32uvPGEh1MrUYLnvlT3sG_BtrNgFn62NT0DsiaJaeC6kmnygPfawxXsMwaAi_OEALw_wcB
£4.33 for 50.
Thanks for the link I have ordered some. I'm probably stuck with DS for the upper & lower races I think it works out at almost £70 for the pair!
« Last Edit: February 08, 2021, 06:04:02 PM by Macabethiele (Ted) »
« Reply #8 on: February 10, 2021, 06:01:53 PM »
Having priced up the parts from DS I'm looking again at your suggestion to fit taper rollers they do seem a cheaper & better option. I've found these on e-bay after a search. What's the catch probably do not fit!! The lower race has a larger OD than the upper one.
https://www.ebay.co.uk/itm/Steering-bearings-taper-roller-Honda-CB250-350-400-450-500-550-650-750-super/153984339007?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
And a spacer https://www.ebay.co.uk/itm/Honda-CB-400-F-Four-75-79-Headstock-Steering-Taper-Bearing-Spacer-OE-324005/184349619747?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
https://www.ebay.co.uk/itm/Honda-CB-400-F-Four-1975-1979-Headstock-Steering-Taper-Bearing-Top-OE-324803/184340453514?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Clearly I need to get my calipers on the old races.
« Reply #9 on: February 11, 2021, 12:15:15 PM »
I've found what sounds like a supplier that will sell me a pair of bearigs with a spacer to suit. Currently out of stock in the cheaper option for my particular model of Honda but the dearer option is £30.00.
As & when the bits arrive I will update with details of my fittment experience.
Offline mickwinf
Offline Seabeowner
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline mickwinf
« Reply #13 on: February 11, 2021, 09:30:42 PM »
i think all 70s hondas from 250-550 used same bearings, my thinking was they would be nearer in depth to the original rather than the taper rollers.
« Reply #14 on: February 12, 2021, 09:48:48 AM »
I have measured my steering shaft & steering column top & bottom diameters as best I can with my Aldi Calipers they come out as follows.
Bottom bearings are 50.00 mm OD, steering shaft diameter is 26.7? mm. ( not sure until I remove the bottom race if has a wider shoulder at the bottom where the race seats)
Top bearings are 48.50 mm OD, 26.00 mm ID.
As best as I can measure the original bottom ball bearing has a thickness of 13.50 mm.
This leads me to thinking that the bottom spacer needs to be the difference between the taper & roller bearing thickness plus any washer (if there is such a thing) that sits between the normal lower bearing race & the dust seal.
Any comments on my calcuations welcome please,
« Last Edit: February 12, 2021, 12:33:52 PM by Macabethiele (Ted) »
