Author Topic: Front forks question ?  (Read 5213 times)
« on: February 09, 2021, 10:28:52 PM »
front forks by Macabe Thiele, on Flickr
How do you remove the plastic shield/cover that sits between the top & bottom section please ?
I'm assuming that the painted section is laquered as there seems to be corrosion between the alloy section & the paint - does anyone know what colour they were painted in originally ?
Clearly I need to strip mine back to bare metal & re-paint them to something close to original finish.
Re: Front forks question ?
« Reply #1 on: February 09, 2021, 10:49:06 PM »
To remove plastic/rubber covers, get them much warmer first to provide more flexibility. Then you can usually gently prise under the bottom edge to start wriggling them up.
They only "clip" into a groove near bottom edge and won't take much to encourage them to move.
Finish was just a fine brushed/burnished plain aluminium with lacquer over that to give them a final look a bit like an oven door in stainless.
As you see, once the lacquer is breached the corrosion creeps along underneath it in those spidery trails.
« Reply #2 on: February 10, 2021, 12:04:06 AM »
A lot of people polish the alloy and leave it like that. I got lazy and painted mine with aluminium colour paint.
Offline Athame57
« Reply #3 on: February 10, 2021, 05:38:06 AM »
K2-K6 has it down to a tee! As for the finish, I removed the old paint and now keep them polished with Autosol, they look great. Same with the brake caliper arm, it's really worth the effort!
1978 CB400F2 named Elen.
Offline heli_madken
« Reply #4 on: February 10, 2021, 10:58:46 AM »
Have a go at polishing them they do seem to be one of the parts that polish easy. If you still have lacquer on the surface I recommend Frost strip Gel - https://www.frost.co.uk/frost-strip-gel-500ml/ it really is like Nitromors used to be, reassuringly nasty to use so make sure you wear thick rubber gloves!
« Reply #5 on: February 10, 2021, 11:32:40 AM »
And the goggles, don't forget the goggles  :)
I'm not necessarily that cautious,  but from working with chemicals realise that soft tissue (eyes) are vulnerable to things of this strength and concentration, and also quite useful in full working order too.
Also put a turnup on rubber glove cuff to avoid contamination running off them onto your arms, again chemical handling sensible precautions.
« Reply #6 on: February 10, 2021, 11:43:53 AM »
I know you are a polisher from previous posts - in this instance I'm inclined  to follow your advice to polish the forks first to see how them come up. (probably not the brake caliper arm though).
Do you use a flap wheel after stripping off the paint?
« Last Edit: February 10, 2021, 01:03:20 PM by Macabethiele (Ted) »
Offline Athame57
« Reply #7 on: February 10, 2021, 04:15:24 PM »
I do use a drill with a polishing kit but I always use a cloth with autosol to finish, especially on the inside where you can't apply drill borne brushes.
Offline heli_madken
« Reply #8 on: February 10, 2021, 06:23:35 PM »
Yes good advice, I wear safety glasses by default and forgot to mention them.
Ted, if the surface of the forks are pitted use some 400 grade wet and dry (used wet) then go to finer grades finishing with 800 before polishing. You can do it by hand with Autosol but a simple lambs wool mop in a drill together with Autosol will do the job very well.
« Reply #9 on: February 12, 2021, 09:50:47 AM »
Thanks everyone for your advice everone  I wil post my progress when I start doing the front forks on my rebuild thread.
Offline waffey
« Reply #10 on: February 12, 2021, 12:34:39 PM »
i used my bench grinder using some abrasive disc's then a polishing mop with auto sol. They come up ok, I didn't plan to get all the large dents out.
Bikes:
Triumph Street Twin
Suzuki Address 110 Scooter
Suzuki TL1000s
BMW R1200GS LC
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #11 on: February 20, 2021, 08:29:24 AM »
^ I did the same.
As a novice polisher, I think it came out pretty well!
« Reply #12 on: February 20, 2021, 08:40:39 AM »
inside fork lef by Macabe Thiele, on Flickroutside fork leg by Macabe Thiele, on Flickr
This is as far as I have got with fork polishing after 30 minutes.
10 minutes with 240 grit W& by hand.
10 minutes with 1200 grit W&D by hand.
5 minutes with Solvolautosal by hand.
5 minutes with Solvolautosol with drill mounted buffing mop.
Still need more polishing but very pleased with the time invested - I'm guessing its diminishing returns from here.
« Last Edit: February 22, 2021, 03:33:07 PM by Macabethiele (Ted) »
« Reply #13 on: February 22, 2021, 03:34:07 PM »
Not as good as Seans yet but I'm surprised at the improvement in such a relatively short space of time.
Offline SeanFD
« Reply #14 on: February 22, 2021, 07:17:18 PM »
You are getting there.
I invested in a kit from these guys - https://www.metalpolishingsupplies.co.uk
With a bit of practice I got the result I showed you; I can recommend it.
