SOHC.co.uk Forums > CB350/400
Just one part left to remove from the frame Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
McCabe-Thiele (Ted):
--- Quote from: Oddjob on February 18, 2021, 01:12:34 PM ---Just cut a slot in it with a hacksaw blade Ted, dismount the blade, run it through the tube and remount, as soon as the blade cuts through the tube the entire length the tube will collapse on it's self very slightly, it will then just knock out no problem. Same system works with swinging arm bearings although that usually needs a forward mounted hacksaw blade
--- End quote ---
So far so bad ! I tried some threaded bar and heat---nada.
I've done the saw cut and nothing has collapsed in on itself tonight. Started doing a second cut nearby to help the collapsing but its still solid. Too tired to do any more tonight - wish I had a 15 mm steel drill bit that would thin the walls somewhat.
I can see the temptation in buying a used stand that has been sorted !!
In the end I resorted to violence using a 15mm masonry bit with the SCS in hammer mode only it finally let go! Thanks for the encouragement everyone!
K2-K6:
--- Quote from: Macabethiele (Ted) on February 20, 2021, 02:23:15 PM ---In the end I resorted to violence using a 15mm masonry bit with the SCS in hammer mode only it finally let go! Thanks for the encouragement everyone!
--- End quote ---
I find this with most things that are well stuck or corroded.
Far from being the most brutal, it seems just more insistent in applying vibration to the work piece and avoids the significant blows a heavy hammer will apply.
I've been using (by making up special adapters) this method for moving things in fairly light structures that I didn't want to damage.
Bryanj:
A hot spanner is your friend in a lot of these cases
Oxy- Acetyleme
This is a "Dead Pivot" as opposed to Parrot
Stand pivot tube by Macabe Thiele, on Flickr
Navigation
[0] Message Index
[*] Previous page
Go to full version
