Author Topic: No Oil Presure  (Read 5304 times)
Offline Phil Ward (RIP)
Re: No Oil Presure
« Reply #15 on: March 14, 2021, 10:06:23 PM »
The oil pump is just not very good at pumping air, if the onward system is resistant (the graphogen is an effective seal in the bearings) it just can't pull the oil into the pump head sufficiently.
By cranking with filter removed it prevents it building air pressure, then once you see the oil arrive into the filter chamber the pump head and pipe both side of it will be purged such that it'll pump the oil easily.
It will usually take only about 30 sec further to fill the galleries with the filter back on.
I'll get on it in the morning - thanks for all your help
Re: No Oil Presure
« Reply #16 on: March 15, 2021, 09:58:22 AM »
All sorted - primed pump and took oil filter off until oil appeared - then filter back on, spun motor for 10 seconds and light out. Panic over.
Thanks all
Re: No Oil Presure
« Reply #17 on: March 15, 2021, 10:06:56 AM »
Nice one. It's always a priming problem.
Offline eight0
Re: No Oil Presure
« Reply #18 on: March 15, 2021, 12:02:52 PM »
Good info. I'll be needing it very soon!
