Cb 550 ss spain
11
12
13
14
15
Topic: Cb 550 ss spain (Read 76462 times)
murdock
SOHC Member
Re: Cb 550 ss spain
Reply #165 on:
May 05, 2021, 10:23:37 PM »
I can't imagine where this one is from either ?
Phil Ward (RIP)
Re: Cb 550 ss spain
Reply #166 on:
May 05, 2021, 10:32:57 PM »
Can't calculate seal size but could it be the seal for the long clutch push rod? 26 in diagram?
https://images.cmsnl.com/img/partslists/honda-cb500k2-general-export-e-15-transmission_big3IMG01171119_410b.gif
murdock
SOHC Member
Re: Cb 550 ss spain
Reply #167 on:
May 05, 2021, 10:45:29 PM »
Thank you very much , you are very kind , maybe I should have told you in the beginning what is a 1977 France F2 and maybe that was not my kit , but I think it will work anyway . I don't know if it will be the same as the oil seal which no longer has the metal washer.
But I think the one in the kit will hold.
In the photo you can see a mark on the trunnion that was made by the washer.
murdock
SOHC Member
Re: Cb 550 ss spain
Reply #168 on:
May 06, 2021, 08:44:20 AM »
Where I bought it I said for 500 and 550 ´this is the product in cmsnl, I think it only varies in the one of the clutch regulator and in the push rod cap, I think I will not have problems
I will replace the same cap
today I'm going to put the parts together
https://www.cmsnl.com/products/oil-seal-kit-oe_90000323000p/
ask the experts, inside the seals do I usually put a little grease for pneumatic seals,
on the outside? Should I put in some Hondabond?
murdock
SOHC Member
Re: Cb 550 ss spain
Reply #169 on:
May 06, 2021, 09:34:58 AM »
ok, no problem, thank you very much
murdock
SOHC Member
Re: Cb 550 ss spain
Reply #170 on:
May 06, 2021, 10:40:26 PM »
Great ! it's already closed , it was easy ,
I will soon put it back on the bike,
I have sent a message to cruzzin , see if I get a reply , it's been 22 days in Japan post is still in Tokio
I think I will have to contact Paypal
One question
Is there any trick to tighten the rotor again ?
murdock
SOHC Member
Re: Cb 550 ss spain
Reply #171 on:
May 10, 2021, 09:21:13 PM »
curiosities
https://www.fb-stuff.com/fb-stuff-store.html
https://www.otherlifecycles.com/product/custom-honda-cb-550-f-super-sport-alternator-cover/
murdock
SOHC Member
Re: Cb 550 ss spain
Reply #172 on:
May 12, 2021, 07:51:11 PM »
Hello, new question for the experts, 2 questions, would someone tell me the size of the thread that comes out of the gas tank? , is to put a reduction to 1/4 and place a hidden tap 550 ss 1977
the other is that I need this part, my motorcycle has never had it and I would like to get it
number 13
gracias
Menno
SOHC Expert
www.tanklackieren.de
Re: Cb 550 ss spain
Reply #173 on:
May 12, 2021, 09:52:53 PM »
There are 2 different types of gas tank for the 550f.
Please show us a picture of the threat.
murdock
SOHC Member
Re: Cb 550 ss spain
Reply #174 on:
November 06, 2021, 07:42:05 PM »
hello again, after rebuilding the engine I think it has not yet run or 100 kilometers and as the motorcycle is the same or worse than before, with the problems of trying to work well with individual filters, changing jets, raising and lowering the needle and removing the carburetors hundreds of times, more than now perfectly configure the points that were never right the problem has worsened and now everything is black smoke this problem I have been carrying for many years I think I will return to the original filter box, my carburettors are the 069 a ( ss 1977 )
I know that the factory setting is 38 slow, 98 main, 22 mm float, but what I am not clear about is the position of the clip, is it the second from bottom to top?
the exhaust is 4 to 1 not original, it is a cheap megaphone that sounds loud, but I don't think it needs any adjustment
Re: Cb 550 ss spain
Reply #175 on:
November 06, 2021, 09:48:25 PM »
Needles originalyin centre groove but oce youalter induction orexhaust all bets are off
murdock
SOHC Member
Re: Cb 550 ss spain
Reply #176 on:
November 06, 2021, 10:03:18 PM »
OK THANKS IN THE MIDDLE OF THE 5 NOTCHES
I DON'T KNOW WHAT IT MEANS (but you change the induction or exhaust all bets are off.) Sorry we don't speak the same language
murdock
SOHC Member
Re: Cb 550 ss spain
Reply #177 on:
November 06, 2021, 10:36:04 PM »
I think you ask me if I change the air inlet, I will replace once and for all what ever the motorcycle had the original air box with all its components except the rubber nozzle that goes under the seat, since I have changed for a flatter seat and it does not fit, I have exhausted my passience with the individual filters, more or less it worked, but, after rebuilding the engine and tuning the ignition, it no longer works well
Last Edit: November 06, 2021, 10:38:46 PM by murdock
Re: Cb 550 ss spain
Reply #178 on:
November 06, 2021, 11:11:38 PM »
It means thatonce you start altringthe inlet or exhaust nobody has any idea of what to do
deltarider
My kingdom for a turkey!
Re: Cb 550 ss spain
Reply #179 on:
November 07, 2021, 07:28:38 AM »
If we're talking the CB550
F
model, there will be no middle position for the jet needle, as there are only 4 positions in total. According to the original Shop Manual Honda CB500-550 p.165*, needle clip needs to be 2
nd
from top. Caution: top is top and
not
tip. When you
lower
the clip on the needle, the needle's position will
rise
and vice versa. Main jet is #98, slow jet #38 and airscrews are supposed to be 1
turn out
turn. This is with genuine Keihin parts in 069A carbs.
Note that jet needles and airscrews differ from those applied in CB500/550
K
models. The
F
models had solid airscrews, the K models were open ended and cross drilled. The jet needle of the
F
models is tapered differently than the needle in the K models. For part numbers, you may consult the PDF below.
https://www.dropbox.com/s/88zdzlj8olqi8pl/Honda%20CB500_CB550
11
12
13
14
15
Cb 550 ss spain
