SOHC.co.uk Forums > CB350/400
Rear Brake Return Spring Location
<< < (2/2)
waffey:
O'm thinking the green spring piece highlighted should go where the red line is?
Nurse Julie:
Yes, I've just had a rummage and I can feel the other tale end going around a bit of tube. If it still doesn't work, I'll try harder tomorrow to take a better pic for you.
waffey:
Hi, still struggling with this damn spring. Any pictures of where ther inside spring locates pleaseeeeeeeeeeeeeeee...
waffey:
OddJob,
I dont have any tension on the spring, thats my issue i believe. I get the tension when the pedal is pressed but when it returns the pedal is floppy as with the spring. Just thinking.........Do i need the footrest installed for it all to work properly, ie the peday return is stopped by the foot rest......i think this could be a Doh moment?
taysidedragon:
--- Quote from: waffey on March 22, 2021, 09:20:03 AM ---OddJob,
--- End quote ---
Yes. The footrest bracket has an adjustable bolt on it that acts as a stop for the brake pedal.
Navigation
[0] Message Index
[*] Previous page
Go to full version
