SOHC.co.uk Forums > CB500/550
Bottom yoke
Sesman:
Thanks Bryanj.
Ted was kind enough to send me a 1mm shim. Now to set about removing the bottom bearing and shim without ruining the bearing...great. Jury is out on the bottom yoke ‘djustment’ until I’ve spoken to DK.
Bryanj:
The inner brg is usualy not that tight on the stem mate
Sesman:
Some 'long bar' action later this am....Fingers crossed.
Sesman:
And a length of scaffold pole ;D Imaginative use of the council drain cover (almost a slip gauge fit for the Stanchion clamp) may be be the solution. Waiting for night fall..... ;). A Norton commando stanchion is the perfect tool.....sacrilege I know.
Sesman:
Update. The CB550 1977 F2 needs a 3mm shim to safely clear the lock stops and bottom yoke. Unfortunately this means the headlamp brackets don’t fit correctly. Just to further reinforce Triggers observations, to make them fit correctly shim the bottom bearing and mill out 6mm from the head stock for the top bearing.
I’m going back to all bearings.... ;D
Navigation
[0] Message Index
[*] Previous page
Go to full version
