SOHC.co.uk Forums > CB350/400
Crankcase - ancient hieroglphics what are these?
<< < (2/2)
McCabe-Thiele (Ted):
--- Quote from: Oddjob on March 21, 2021, 03:38:05 PM ---The fact there's a C there Ted isn't the best news, the only colours ever fitted to that journal would have been either brown, black or blue. Black and blue are very hard to find.
On the crankshaft are 5 numbers and 4 letters printed onto the edge of the webs, see if you can find them. Also there are numbers and letter on the rods.
--- End quote ---
The conrods have a large leter C on them, I haven't taken the crank right out yet but have undone No:2 conrod & the big end shell was in good condition.
--- Quote from: Oddjob on March 21, 2021, 06:15:14 PM ---C is the weight code, Honda made sure that all the conrods weighed the same so the crank was better balanced. It also means if you ever need a new conrod you had to order it by weight code. One the other side of the rod will be a number, that's the diameter of the journal the rod goes on.
--- End quote ---
Only two of my conrods have numbers on the opposite side to the big C  - one marked  2 was in cylinder 4 , one was marked 3 was in cylinder 1. The other two rods had no legible markings aside from the big C.
Bryanj:
And here was me thinking it was a Millyard special!!
--- Quote from: Oddjob on March 21, 2021, 09:12:12 PM ---You do realise Ted that the 400 only has 4 cylinders 😯😯
--- End quote ---
Just a typo but in my defence it does have a 5 bearing crank!
--- Quote from: Bryanj on March 21, 2021, 09:42:37 PM ---And here was me thinking it was a Millyard special!!
--- End quote ---
In my defence I have had to invert all my markings as the engine is upside down - just a typo 4 is next to 5 on my keyboard - sorry for the drama.
Navigation
[0] Message Index
[*] Previous page
Go to full version
