General > New Member Introductions
Hello from Shropshire UK
400 Cafe Racer:
--- Quote from: SteveD CB500K0 on March 30, 2021, 10:33:55 AM ---Which is the. Est for the shopping?
The Honda, the Velo or the Lambo?
--- End quote ---
Well Steve, I sold the Countach in 2009 - so thats out, the Honda doesn't have any load space, - SO I thnk its possibly the Velo - with bags of low down torque.!!! ;D ;D
Can anyone help with the following from your collective forum experiences please.
1. The thread size of the 4 manifold vacuum screws used for the test adaptors used on the vacuum pipes.
2. The kit model that you regard as successful.
3. Good UK supplier for service bits and "O" rings etc.
4. The majority concensus on the Brand and spec of the Engine oil for the 400/4. (Currently considering Motul 5000 MA2) (I know asking about engine oils can be a can of worms, so feel that the concensus may be the best approach.
Dennis ;D
400 Cafe Racer:
--- Quote from: taysidedragon on March 30, 2021, 11:13:35 AM ---Nice machines. 👍
Please tell me that you're going to improve the 400 rear brake pedal. I couldn't live with that Allen bolt sticking out! 😣
--- End quote ---
Hi taysidedragon, well spotted. ;) Yes its on the " to do" list, but at least its solid for now until i can source a nice replacement. Any suggestions from your experience please
Phil Ward (RIP):
500 vucuum guage inlet screws are 5mm - would imagine same for 400 - Nurse Julie does seals for all the SOHC cam fours (upgraded)
No ides of best guages as my dad made my set up in work 49 years ago - still working great! Thanks Dad!
400 Cafe Racer:
--- Quote from: philward on March 30, 2021, 01:04:37 PM ---500 vucuum guage inlet screws are 5mm - would imagine same for 400 - Nurse Julie does seals for all the SOHC cam fours (upgraded)
--- End quote ---
Hi Phil, thanks for your help with those, ;D I will make a note when I do my Internet searches for guages and may need to replace O rings when I check the valve clearances.
I forgot to add to my list - Rear sprocket - nothing fancy, just well engineered and durable, what do regard as best/good value
The chain is new and the g/box sprocket v.good.
Bryanj:
Best vacuum gauges in my opinion, and most like original Honda, are Sealey and cost about £135 on ebay plus come with all adaptors. There are similar looking ones costing about £50 but the actual gauges are cheap and will not be as accurate.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
